1 #ifndef __CS_MEDCOUPLING_INTERSECTOR_HXX__ 2 #define __CS_MEDCOUPLING_INTERSECTOR_HXX__ 45 typedef struct _cs_medcoupling_intersector_t cs_medcoupling_intersector_t;
65 const char *medfile_path,
66 const char *interp_method,
67 const char *select_criteria);
99 cs_medcoupling_intersector_t *
112 cs_medcoupling_intersector_t *
198 const char *dir_name,
199 const char *fmt_name,
200 const char *fmt_opts,
202 bool output_at_start,
cs_medcoupling_intersector_t * cs_medcoupling_intersector_by_id(int id)
Get a MEDCoupling intersector using its id.
Definition: cs_medcoupling_intersector.cxx:671
void cs_medcoupling_intersector_destroy_all(void)
Free all allocated intersectors.
Definition: cs_medcoupling_intersector.cxx:646
void cs_medcoupling_intersector_translate(cs_medcoupling_intersector_t *mi, cs_real_t translation[3])
translate the mesh using a given vector
Definition: cs_medcoupling_intersector.cxx:753
Definition: cs_defs.h:495
void cs_medcoupling_intersector_add(const char *name, const char *medfile_path, const char *interp_method, const char *select_criteria)
Add a MEDCoupling intersector.
Definition: cs_medcoupling_intersector.cxx:583
void cs_medcoupling_intersector_rotate(cs_medcoupling_intersector_t *mi, cs_real_t invariant[3], cs_real_t axis[3], cs_real_t angle)
rotate the mesh
Definition: cs_medcoupling_intersector.cxx:810
fvm_writer_time_dep_t
Definition: fvm_writer.h:57
void cs_medcoupling_intersector_dump_mesh(cs_medcoupling_intersector_t *mi, const char *prefix)
Definition: cs_medcoupling_intersector.cxx:904
Definition: cs_defs.h:307
Definition: cs_matrix_building.c:112
void cs_medcoupling_intersector_destroy(cs_medcoupling_intersector_t *mi)
Destroy a given MEDCoupling intersector.
Definition: cs_medcoupling_intersector.cxx:625
cs_medcoupling_intersector_t * cs_medcoupling_intersector_by_name(const char *name)
Get a MEDCoupling intersector by name.
Definition: cs_medcoupling_intersector.cxx:692
void cs_mi_post_add_mesh(cs_medcoupling_intersector_t *mi)
Associate a Medcoupling mesh to the default writer.
Definition: cs_medcoupling_intersector.cxx:971
void cs_mi_post_init_writer(const char *case_name, const char *dir_name, const char *fmt_name, const char *fmt_opts, fvm_writer_time_dep_t time_dep, bool output_at_start, bool output_at_end, int frequency_n, double frequency_t)
Create a new writer that will contains the boundary MED mesh added.
Definition: cs_medcoupling_intersector.cxx:928
void cs_medcoupling_intersector_transform_from_init(cs_medcoupling_intersector_t *mi, cs_real_t matrix[3][4])
Transform a mesh, but takes as input the initial position of the mesh.
Definition: cs_medcoupling_intersector.cxx:858
Definition: cs_defs.h:496
cs_real_t * cs_medcoupling_intersect_volumes(cs_medcoupling_intersector_t *mi)
Compute the intersection volumes between the source mesh and code mesh.
Definition: cs_medcoupling_intersector.cxx:720
