cs_lagr_extract.h
1 #ifndef __CS_LAGR_EXTRACT_H__
2 #define __CS_LAGR_EXTRACT_H__
5  * Extract information from lagrangian particles.
35  * Local headers
38 #include "fvm_nodal.h"
39 #include "fvm_writer.h"
41 #include "cs_base.h"
42 #include "cs_lagr_particle.h"
43 #include "cs_time_step.h"
45 /*----------------------------------------------------------------------------*/
46
48
50  * Macro definitions
52
54  * Local type definitions
56
57 /*=============================================================================
58  * Global variables
59  *============================================================================*/
60
61 /*============================================================================
62  * Public function prototypes
63  *============================================================================*/
64
65 /*----------------------------------------------------------------------------
66  * Get the local number of particles.
67  *
68  * returns:
69  * current number of particles.
70  *----------------------------------------------------------------------------*/
71
74
75 /*----------------------------------------------------------------------------
76  * Extract a list of particles using an optional cell filter and
77  * statistical density filter.
78  *
79  * The output array must have been allocated by the caller and be of
80  * sufficient size.
81  *
82  * parameters:
83  * n_cells <-- number of cells in filter
84  * cell_list <-- optional list of containing cells filter
85  * (1 to n numbering)
86  * density <-- if < 1, fraction of particles to select
87  * n_particles --> number of selected particles, or NULL
88  * particle_list --> particle_list (1 to n numbering), or NULL
89  *----------------------------------------------------------------------------*/
90
91 void
93  const cs_lnum_t cell_list[],
94  double density,
95  cs_lnum_t *n_particles,
96  cs_lnum_t *particle_list);
97
98 /*----------------------------------------------------------------------------
99  * Extract values for a set of particles.
100  *
101  * The output array must have been allocated by the caller and be of
102  * sufficient size.
103  *
104  * parameters:
105  * particle_set <-- associated particle set
106  * attr <-- attribute whose values are required
107  * datatype <-- associated value type
108  * stride <-- number of values per particle
109  * component_id <-- if -1 : extract the whole attribute
110  * if >0 : id of the component to extract
111  * n_particles <-- number of particles in filter
112  * particle_list <-- particle_list (1 to n numbering), or NULL
113  * values --> particle values for given attribute
114  *
115  * returns:
116  * 0 in case of success, 1 if attribute is not present
117  *----------------------------------------------------------------------------*/
118
119 int
121  cs_lagr_attribute_t attr,
122  cs_datatype_t datatype,
123  int stride,
124  int component_id,
125  cs_lnum_t n_particles,
126  const cs_lnum_t particle_list[],
127  void *values);
128
129 /*----------------------------------------------------------------------------
130  * Extract trajectory values for a set of particles.
131  *
132  * Trajectories are defined as a mesh of segments, whose start and end
133  * points are copied in an interleaved manner in the segment_values array
134  * (p1_old, p1_new, p2_old, p2_new, ... pn_old, pn_new).
135  *
136  * The output array must have been allocated by the caller and be of
137  * sufficient size.
138  *
139  * parameters:
140  * particles <-- associated particle set
141  * attr <-- attribute whose values are required
142  * datatype <-- associated value type
143  * stride <-- number of values per particle
144  * component_id <-- if -1 : extract the whole attribute
145  * if >0 : id of the component to extract
146  * n_particles <-- number of particles in filter
147  * particle_list <-- particle_list (1 to n numbering), or NULL
148  * segment_values --> particle segment values
149  *
150  * returns:
151  * 0 in case of success, 1 if attribute is not present
152  *----------------------------------------------------------------------------*/
153
154 int
156  cs_lagr_attribute_t attr,
157  cs_datatype_t datatype,
158  int stride,
159  int component_id,
160  cs_lnum_t n_particles,
161  const cs_lnum_t particle_list[],
162  void *segment_values);
163
164 /*----------------------------------------------------------------------------*/
165
167
168 #endif /* __CS_LAGR_EXTRACT_H__ */
cs_datatype_t
Definition: cs_defs.h:260
Definition: cs_defs.h:495
Definition: cs_lagr_particle.h:222
cs_lagr_attribute_t
Definition: cs_lagr_particle.h:79
int cs_lagr_get_trajectory_values(const cs_lagr_particle_set_t *particles, cs_lagr_attribute_t attr, cs_datatype_t datatype, int stride, int component_id, cs_lnum_t n_particles, const cs_lnum_t particle_list[], void *segment_values)
Definition: cs_lagr_extract.c:362
int cs_lagr_get_particle_values(const cs_lagr_particle_set_t *particles, cs_lagr_attribute_t attr, cs_datatype_t datatype, int stride, int component_id, cs_lnum_t n_particles, const cs_lnum_t particle_list[], void *values)
Definition: cs_lagr_extract.c:260
double precision, dimension(:,:,:), allocatable density
Definition: atimbr.f90:124
void cs_lagr_get_particle_list(cs_lnum_t n_cells, const cs_lnum_t cell_list[], double density, cs_lnum_t *n_particles, cs_lnum_t *particle_list)
Extract a list of particles using an optional cell filter and statistical density filter...
Definition: cs_lagr_extract.c:134
Definition: cs_defs.h:301
Definition: cs_defs.h:496
cs_lnum_t cs_lagr_get_n_particles(void)
Definition: cs_lagr_extract.c:105
