cs_join_update.h
1 #ifndef __CS_JOIN_UPDATE_H__
2 #define __CS_JOIN_UPDATE_H__
5  * Structure and function headers handling with mesh update during
6  * the joining operation
7  *===========================================================================*/
8
9 /*
10  This file is part of Code_Saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2021 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
30
31 /*----------------------------------------------------------------------------
32  * Local headers
33  *---------------------------------------------------------------------------*/
34
35 #include "cs_base.h"
36 #include "cs_join_mesh.h"
37 #include "cs_join_set.h"
38 #include "cs_join_util.h"
39 #include "cs_mesh.h"
41 /*---------------------------------------------------------------------------*/
46  * Local Macro definitions
47  *===========================================================================*/
48
50  * Type definition
51  *===========================================================================*/
52
53 /*=============================================================================
54  * Global variables
55  *===========================================================================*/
56
57 /*============================================================================
58  * Public function header for Fortran API
59  *===========================================================================*/
60
61 /*=============================================================================
62  * Public function prototypes
63  *===========================================================================*/
64
65 /*----------------------------------------------------------------------------
66  * Update mesh structure (vertices + faces) after the fusion step.
67  *
68  * parameters:
69  * join_param <-- set of parameters for the joining operation
70  * join_select <-- list of all implied entities in the joining op.
71  * o2n_vtx_gnum <-> in : array on blocks on the new global vertex
72  * out: local array on the new global vertex
73  * join_mesh <-> pointer to the local cs_join_mesh_t structure
74  * mesh <-> pointer of pointer to cs_mesh_t structure
75  *---------------------------------------------------------------------------*/
76
77 void
79  cs_join_select_t *join_select,
80  cs_gnum_t o2n_vtx_gnum[],
81  cs_join_mesh_t *join_mesh,
82  cs_mesh_t *mesh);
83
84 /*----------------------------------------------------------------------------
85  * Update mesh structure (vertices + faces) after the face split step.
86  *
87  * parameters:
88  * join_param <-- set of parameters for the joining operation
89  * join_select <-- list of all implied entities in the joining op.
90  * o2n_face_hist <-- relation between faces before/after the joining
91  * join_mesh <-> pointer to the local cs_join_mesh_t structure
92  * mesh <-> pointer of pointer to cs_mesh_t structure
93  * mesh_builder <-> pointer of pointer to cs_mesh__builder_t structure
94  *---------------------------------------------------------------------------*/
95
96 void
98  const cs_join_select_t *join_select,
99  const cs_join_gset_t *o2n_face_hist,
100  cs_join_mesh_t *join_mesh,
101  cs_mesh_t *mesh,
102  cs_mesh_builder_t *mesh_builder);
103
104 /*----------------------------------------------------------------------------
105  * Clean a cs_mesh_t struct.
106  * Delete redundant and empty edge definitions.
107  *
108  * parameters:
109  * para <-- set of parameters for the joining operation
110  * mesh <-> pointer to a cs_mesh_t structure
111  *---------------------------------------------------------------------------*/
112
113 void
115  cs_mesh_t *mesh);
116
117 /*---------------------------------------------------------------------------*/
118
120
121 #endif /* __CS_JOIN_UPDATE_H__ */
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:286
void cs_join_update_mesh_clean(cs_join_param_t param, cs_mesh_t *mesh)
Definition: cs_join_update.c:4507
Definition: cs_mesh_builder.h:57
void cs_join_update_mesh_after_split(cs_join_param_t join_param, const cs_join_select_t *join_select, const cs_join_gset_t *o2n_face_hist, cs_join_mesh_t *join_mesh, cs_mesh_t *mesh, cs_mesh_builder_t *mesh_builder)
Definition: cs_join_update.c:4186
Definition: cs_defs.h:495
Definition: cs_mesh.h:84
void cs_join_update_mesh_after_merge(cs_join_param_t join_param, cs_join_select_t *join_select, cs_gnum_t o2n_vtx_gnum[], cs_join_mesh_t *join_mesh, cs_mesh_t *mesh)
Definition: cs_join_update.c:3959
Definition: cs_defs.h:496
Definition: cs_join_util.h:115
Definition: mesh.f90:26
