1 #ifndef __CS_JOIN_MESH_H__ 2 #define __CS_JOIN_MESH_H__ 57 CS_JOIN_FACE_UNDEFINED,
60 CS_JOIN_FACE_MULTIPLE_BORDER,
63 } cs_join_face_type_t;
122 cs_join_vertex_t *vertices;
168 const cs_join_mesh_t *local_mesh);
190 const cs_join_mesh_t *parent_mesh);
215 cs_join_select_t *selection,
254 const cs_join_mesh_t *ref_mesh);
266 cs_join_mesh_t *
mesh);
268 #if defined(HAVE_MPI) 285 const int send_rank[],
287 const cs_join_mesh_t *send_mesh,
288 cs_join_mesh_t *recv_mesh,
380 const cs_join_edges_t *edges);
398 const cs_join_edges_t *edges,
447 const cs_join_edges_t *edges,
461 const cs_join_vertex_t vertex);
473 const cs_join_mesh_t *
mesh);
486 const cs_join_edges_t *edges,
487 const cs_join_mesh_t *
mesh);
void cs_join_mesh_destroy(cs_join_mesh_t **mesh)
Definition: cs_join_mesh.c:1873
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:286
void cs_join_mesh_update(cs_join_mesh_t *mesh, const cs_join_edges_t *edges, const cs_lnum_t edge_index[], const cs_lnum_t edge_new_vtx_lst[], cs_lnum_t n_new_vertices, const cs_lnum_t old2new[])
Definition: cs_join_mesh.c:3054
void cs_join_mesh_copy(cs_join_mesh_t **mesh, const cs_join_mesh_t *ref_mesh)
Definition: cs_join_mesh.c:1924
cs_real_t * cs_join_mesh_get_face_normal(const cs_join_mesh_t *mesh)
Definition: cs_join_mesh.c:3268
void cs_join_mesh_dump(FILE *f, const cs_join_mesh_t *mesh)
Definition: cs_join_mesh.c:3557
Definition: cs_defs.h:495
cs_lnum_t cs_join_mesh_get_edge(cs_lnum_t v1_num, cs_lnum_t v2_num, const cs_join_edges_t *edges)
Definition: cs_join_mesh.c:3003
void cs_join_mesh_get_edge_face_adj(const cs_join_mesh_t *mesh, const cs_join_edges_t *edges, cs_lnum_t *edge_face_idx[], cs_lnum_t *edge_face_lst[])
Definition: cs_join_mesh.c:3392
Definition: cs_defs.h:307
cs_join_edges_t * cs_join_mesh_define_edges(const cs_join_mesh_t *mesh)
Definition: cs_join_mesh.c:2660
void cs_join_mesh_clean(cs_join_mesh_t *mesh, int verbosity)
Definition: cs_join_mesh.c:2612
void cs_join_mesh_minmax_tol(cs_join_param_t param, cs_join_mesh_t *mesh)
Definition: cs_join_mesh.c:1981
void cs_join_mesh_face_order(cs_join_mesh_t *mesh)
Definition: cs_join_mesh.c:2282
void cs_join_mesh_dump_edges(FILE *f, const cs_join_edges_t *edges, const cs_join_mesh_t *mesh)
Definition: cs_join_mesh.c:3678
cs_join_mesh_t * cs_join_mesh_create_from_glob_sel(const char *mesh_name, cs_lnum_t n_elts, const cs_gnum_t glob_sel[], const cs_gnum_t gnum_rank_index[], const cs_join_mesh_t *local_mesh)
Definition: cs_join_mesh.c:1515
void cs_join_mesh_dump_vertex(FILE *f, const cs_join_vertex_t vertex)
Definition: cs_join_mesh.c:3536
cs_join_mesh_t * cs_join_mesh_create_from_select(const char *name, const cs_join_param_t param, cs_join_select_t *selection, const cs_lnum_t b_f2v_idx[], const cs_lnum_t b_f2v_lst[], const cs_lnum_t i_f2v_idx[], const cs_lnum_t i_f2v_lst[], const cs_lnum_t n_vertices, const cs_real_t vtx_coord[], const cs_gnum_t vtx_gnum[])
Definition: cs_join_mesh.c:1773
cs_join_state_t
Definition: cs_join_util.h:63
cs_join_mesh_t * cs_join_mesh_create(const char *name)
Definition: cs_join_mesh.c:1466
void cs_join_mesh_reset(cs_join_mesh_t *mesh)
Definition: cs_join_mesh.c:1897
Definition: cs_defs.h:301
Definition: cs_defs.h:496
void cs_join_mesh_destroy_edges(cs_join_edges_t **edges)
Definition: cs_join_mesh.c:2253
void cs_join_mesh_sync_vertices(cs_join_mesh_t *mesh)
Definition: cs_join_util.h:115
void cs_join_mesh_vertex_clean(cs_join_mesh_t *mesh)
Definition: cs_join_mesh.c:2505
cs_join_mesh_t * cs_join_mesh_create_from_subset(const char *mesh_name, cs_lnum_t subset_size, const cs_lnum_t selection[], const cs_join_mesh_t *parent_mesh)
Definition: cs_join_mesh.c:1600
