cs_gwf_parameters.h
1 #ifndef __CS_GWF_PARAMETERS_H__
2 #define __CS_GWF_PARAMETERS_H__
5  * General parameters management for groundwater flow module.
34 #include <stdarg.h>
37  * Local headers
40 #include "cs_defs.h"
41 #include "cs_field.h"
46
48  * Macro definitions
50
52  * Type definitions
54
55 /* Parameter check behavior when an error is detected */
56
58  * Structure defining the sorption model
59  *----------------------------------------------------------------------------*/
60
61 typedef struct {
62
63  int kinetic; /* 0 : sorption at equilibirum
64  1 : sorption with kinetic */
65  int ikd; /* id for kd */
66  int idel; /* id for delay */
67  int ikp; /* id for kplus */
68  int ikm; /* id for kminus */
69  int imxsol; /* id for solubility index */
70  int anai; /* 0: solve EK model in an explicit way
71  1: use analytical solution for EK model */
72
74
75 /*============================================================================
76  * Static global variables
77  *============================================================================*/
78
79 /*=============================================================================
80  * Public function prototypes
81  *============================================================================*/
82
83 /*----------------------------------------------------------------------------*/
87 /*----------------------------------------------------------------------------*/
88
89 void
91
92 /*----------------------------------------------------------------------------*/
93
95
96 #endif /* __CS_GWF_PARAMETERS_H__ */
int ikm
Definition: cs_gwf_parameters.h:68
int imxsol
Definition: cs_gwf_parameters.h:69
Definition: cs_defs.h:495
int kinetic
Definition: cs_gwf_parameters.h:63
void cs_gwf_parameters_define_field_keys(void)
Define field keys for the ground water flow module.
Definition: cs_gwf_parameters.c:156
int anai
Definition: cs_gwf_parameters.h:70
Definition: cs_gwf_parameters.h:61
int ikp
Definition: cs_gwf_parameters.h:67
int idel
Definition: cs_gwf_parameters.h:66
Definition: cs_defs.h:496
int ikd
Definition: cs_gwf_parameters.h:65
