cs_gui_output.h
1 #ifndef __CS_GUI_OUTPUT_H__
2 #define __CS_GUI_OUTPUT_H__
5  * Management of the GUI parameters file: main parameters
31  * Local headers
34 #include "cs_base.h"
41  * Type definitions
45  * Public function prototypes for Fortran API
48 /*----------------------------------------------------------------------------
49  * Determine output boundary fields
50  *----------------------------------------------------------------------------*/
51
52 void CS_PROCF (cspstb, CSPSTB) (int *ipstdv);
53
55  * Public function prototypes
57
58 /*----------------------------------------------------------------------------
59  * Determine general output options.
60  *----------------------------------------------------------------------------*/
61
62 void
63 cs_gui_output(void);
64
65 /*----------------------------------------------------------------------------
66  * Define postprocessing meshes using an XML file.
67  *----------------------------------------------------------------------------*/
68
69 void
71
72 /*----------------------------------------------------------------------------
73  * Define postprocessing writers using an XML file.
74  *----------------------------------------------------------------------------*/
75
76 void
78
79 /*----------------------------------------------------------------------------*/
80
82
83 #endif /* __CS_GUI_OUTPUT_H__ */
void cs_gui_postprocess_meshes(void)
Definition: cs_gui_output.c:741
Definition: cs_defs.h:495
void cs_gui_output(void)
Definition: cs_gui_output.c:683
void cspstb(int *ipstdv)
Definition: cs_gui_output.c:629
void cs_gui_postprocess_writers(void)
Definition: cs_gui_output.c:913
Definition: cs_defs.h:496
integer, dimension(5), save ipstdv
indicates the data to post-process on the boundary mesh (the boundary mesh must be associated with an...
Definition: entsor.f90:175
#define CS_PROCF(x, y)
Definition: cs_defs.h:509
