1 #ifndef __CS_GRADIENT_H__ 2 #define __CS_GRADIENT_H__ 111 const int *
const f_id,
113 const int *
const inc,
114 const int *
const n_r_sweeps,
115 const int *
const iwarnp,
116 const int *
const imligp,
void cs_gradient_scalar(const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, bool recompute_cocg, int n_r_sweeps, int tr_dim, int hyd_p_flag, int w_stride, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, cs_real_3_t f_ext[], const cs_real_t bc_coeff_a[], const cs_real_t bc_coeff_b[], cs_real_t var[restrict], cs_real_t *restrict c_weight, const cs_internal_coupling_t *cpl, cs_real_t grad[restrict][3])
Compute cell gradient of scalar field or component of vector or tensor field.
Definition: cs_gradient.c:8913
#define restrict
Definition: cs_defs.h:127
void cs_gradient_free_quantities(void)
Free saved gradient quantities.
Definition: cs_gradient.c:8866
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:322
Definition: cs_gradient.h:72
void cs_gradient_finalize(void)
Finalize gradient computation API.
Definition: cs_gradient.c:8831
void cs_gradient_tensor(const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_real_6_t bc_coeff_a[], const cs_real_66_t bc_coeff_b[], cs_real_6_t *restrict var, cs_real_63_t *restrict grad)
Compute cell gradient of tensor.
Definition: cs_gradient.c:9129
Definition: cs_gradient.h:73
cs_real_t cs_real_66_t[6][6]
6x6 matrix of floating-point values
Definition: cs_defs.h:328
void cs_gradient_scalar_synced_input(const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, bool recompute_cocg, int n_r_sweeps, int tr_dim, int hyd_p_flag, int w_stride, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, cs_real_t f_ext[][3], const cs_real_t bc_coeff_a[], const cs_real_t bc_coeff_b[], const cs_real_t var[restrict], const cs_real_t c_weight[restrict], const cs_internal_coupling_t *cpl, cs_real_t grad[restrict][3])
Definition: cs_gradient.c:9235
void cs_gradient_type_by_imrgra(int imrgra, cs_gradient_type_t *gradient_type, cs_halo_type_t *halo_type)
Definition: cs_gradient.c:10345
Definition: cs_internal_coupling.h:63
Definition: cs_defs.h:495
Definition: cs_gradient.h:76
cs_gradient_limit_t
Definition: cs_gradient.h:70
void cs_gradient_tensor_synced_input(const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_real_t bc_coeff_a[][6], const cs_real_t bc_coeff_b[][6][6], const cs_real_t var[restrict][6], cs_real_63_t *restrict grad)
Definition: cs_gradient.c:9425
Definition: cs_defs.h:307
void cs_gradient_scalar_cell(const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t c_id, cs_halo_type_t halo_type, const cs_real_t bc_coeff_a[], const cs_real_t bc_coeff_b[], const cs_real_t var[], const cs_real_t c_weight[], cs_real_t grad[3])
Compute the gradient of a scalar field at a given cell using least-squares reconstruction.
Definition: cs_gradient.c:9509
void cs_gradient_vector_cell(const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t c_id, cs_halo_type_t halo_type, const cs_real_t bc_coeff_a[][3], const cs_real_t bc_coeff_b[][3][3], const cs_real_t var[restrict][3], const cs_real_t c_weight[], cs_real_t grad[3][3])
Compute the gradient of a vector field at a given cell using least-squares reconstruction.
Definition: cs_gradient.c:9763
Definition: cs_gradient.h:58
Definition: cs_gradient.h:62
Definition: cs_gradient.h:60
void grdpor(const int *const inc)
Definition: cs_gradient.c:8556
cs_halo_type_t
Definition: cs_halo.h:50
cs_gradient_type_t
Definition: cs_gradient.h:56
void cgdvec(const int *const f_id, const int *const imrgra, const int *const inc, const int *const n_r_sweeps, const int *const iwarnp, const int *const imligp, const cs_real_t *const epsrgp, const cs_real_t *const climgp, const cs_real_3_t coefav[], const cs_real_33_t coefbv[], cs_real_3_t pvar[], cs_real_33_t grad[])
Definition: cs_gradient.c:8738
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:320
Definition: cs_defs.h:301
Definition: cs_defs.h:496
void cs_gradient_tensor_cell(const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, cs_lnum_t c_id, cs_halo_type_t halo_type, const cs_real_t bc_coeff_a[][6], const cs_real_t bc_coeff_b[][6][6], const cs_real_t var[restrict][6], const cs_real_t c_weight[], cs_real_t grad[6][3])
Compute the gradient of a tensor field at a given cell using least-squares reconstruction.
Definition: cs_gradient.c:10063
Definition: cs_gradient.h:59
#define CS_PROCF(x, y)
Definition: cs_defs.h:509
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:327
void cs_gradient_vector(const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_real_t bc_coeff_a[][3], const cs_real_t bc_coeff_b[][3][3], cs_real_t var[restrict][3], cs_real_t *restrict c_weight, const cs_internal_coupling_t *cpl, cs_real_t gradv[restrict][3][3])
Compute cell gradient of vector field.
Definition: cs_gradient.c:9031
cs_real_t cs_real_63_t[6][3]
Definition: cs_defs.h:335
const char * cs_gradient_type_name[]
void cs_gradient_initialize(void)
Initialize gradient computation API.
Definition: cs_gradient.c:8810
void cs_gradient_vector_synced_input(const char *var_name, cs_gradient_type_t gradient_type, cs_halo_type_t halo_type, int inc, int n_r_sweeps, int verbosity, cs_gradient_limit_t clip_mode, double epsilon, double clip_coeff, const cs_real_t bc_coeff_a[][3], const cs_real_t bc_coeff_b[][3][3], const cs_real_t var[restrict][3], const cs_real_t c_weight[restrict], const cs_internal_coupling_t *cpl, cs_real_t grad[restrict][3][3])
Definition: cs_gradient.c:9340
integer(c_int), pointer, save imrgra
type of gradient reconstruction
Definition: optcal.f90:251
