cs_gas_mix.h
1 #ifndef __CS_GAS_MIX_H__
2 #define __CS_GAS_MIX_H__
5  * Base gas mix data.
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
45  * Type definitions
48 /* Gas mix descriptor */
49 /*-------------------------------*/
50
51 typedef struct {
52
53  int n_species; /* number of species in the gas mix */
54  int *sp_id_to_f_id; /* array of species f_ids */
55
56 } cs_gas_mix_t;
57
59  * Static global variables
61
62 /* Pointer to main physical constants structure */
63
64 extern const cs_gas_mix_t *cs_glob_gas_mix;
65
66 /*=============================================================================
67  * Public function prototypes
68  *============================================================================*/
69
70 /*----------------------------------------------------------------------------*/
76 /*----------------------------------------------------------------------------*/
77
78 void
79 cs_gas_mix_add_species(int f_id);
80
81 /*----------------------------------------------------------------------------*/
86
87 void
89
91
93
94 #endif /* __CS_GAS_MIX_H__ */
void cs_gas_mix_finalize(void)
Free array mapping gas mix species ids to field ids.
Definition: cs_gas_mix.c:193
Definition: cs_defs.h:495
const cs_gas_mix_t * cs_glob_gas_mix
Definition: cs_gas_mix.c:111
int * sp_id_to_f_id
Definition: cs_gas_mix.h:54
Definition: cs_defs.h:496
void cs_gas_mix_add_species(int f_id)
Add a species field to the gas mix (set of fields).
Definition: cs_gas_mix.c:162
Gas mix descriptor.
Definition: cs_gas_mix.h:51
int n_species
Definition: cs_gas_mix.h:53
