Fuel example
Fuel example
Local variables to be added
The following local variables need to be defined for the examples in this section:
integer iel, ige, mode, icla
integer ioxy
double precision t1init, h1init, coefe(ngazem)
double precision t2init, h2init
double precision xkent, xeent, d2s3
double precision dmas , wmco2 , wmh2o , wmn2 , wmo2
double precision, dimension(:), pointer :: cvar_k, cvar_ep, cvar_phi
double precision, dimension(:), pointer :: cvar_fb, cvar_omg
double precision, dimension(:), pointer :: cvar_r11, cvar_r22, cvar_r33
double precision, dimension(:), pointer :: cvar_r12, cvar_r13, cvar_r23
double precision, dimension(:), pointer :: cvar_yfol, cvar_ng, cvar_h2
double precision, dimension(:), pointer :: cvar_scalt
double precision, dimension(:), pointer :: cvar_fvap, cvar_f7m, cvar_fvp2m
double precision, dimension(:), pointer :: cvar_yco2, cvar_yhcn, cvar_yno
double precision, dimension(:), pointer :: cvar_hox
Allocation
Before user initialization, work arrays lstelt must be allocated, like in basic example.
Initialization
The following initialization block needs to be added for the following examples:
d2s3 = 2.d0/3.d0
! Variables initialization:
! ONLY done if there is no restart computation
if ( isuite.eq.0 ) then
! --> Initialisation of k and epsilon (exemple)
xkent = 1.d-10
xeent = 1.d-10
! ---- TURBULENCE
if (itytur.eq.2) then
call field_get_val_s(ivarfl(ik), cvar_k)
call field_get_val_s(ivarfl(iep), cvar_ep)
do iel = 1, ncel
cvar_k(iel) = xkent
cvar_ep(iel) = xeent
enddo
elseif (itytur.eq.3) then
call field_get_val_s(ivarfl(ir11), cvar_r11)
call field_get_val_s(ivarfl(ir22), cvar_r22)
call field_get_val_s(ivarfl(ir33), cvar_r33)
call field_get_val_s(ivarfl(ir12), cvar_r12)
call field_get_val_s(ivarfl(ir13), cvar_r13)
call field_get_val_s(ivarfl(ir23), cvar_r23)
do iel = 1, ncel
cvar_r11(iel) = d2s3*xkent
cvar_r22(iel) = d2s3*xkent
cvar_r33(iel) = d2s3*xkent
cvar_r12(iel) = 0.d0
cvar_r13(iel) = 0.d0
cvar_r23(iel) = 0.d0
enddo
elseif (iturb.eq.50) then
call field_get_val_s(ivarfl(iphi), cvar_phi)
call field_get_val_s(ivarfl(ifb), cvar_fb)
do iel = 1, ncel
cvar_k(iel) = xkent
cvar_phi(iel) = d2s3
cvar_fb(iel) = 0.d0
enddo
elseif (iturb.eq.60) then
call field_get_val_s(ivarfl(iomg), cvar_omg)
do iel = 1, ncel
cvar_k(iel) = xkent
cvar_omg(iel) = xeent/cmu/xkent
enddo
endif
! --> All the computation domain is initialized with air at TINITK
! ---- Computation of H1INIT and H2INIT
t1init = 1000.d0
t2init = 1000.d0
! ------ Transported variables for droplets
h2init = h02fol + cp2fol*(t2init-trefth)
do icla = 1, nclafu
call field_get_val_s(ivarfl(isca(iyfol(icla))), cvar_yfol)
call field_get_val_s(ivarfl(isca(ing(icla))), cvar_ng)
call field_get_val_s(ivarfl(isca(ih2(icla))), cvar_h2)
do iel = 1, ncel
cvar_yfol(iel) = zero
cvar_ng(iel) = zero
cvar_h2(iel) = zero
enddo
enddo
! ------ Transported variables for the mix (droplets and carrying gases)
do ige = 1, ngazem
coefe(ige) = zero
enddo
! On considere l'oxydant 1
coefe(io2) = wmole(io2)*oxyo2(1) &
/( wmole(io2) *oxyo2(1) +wmole(in2) *oxyn2(1) &
+wmole(ih2o)*oxyh2o(1)+wmole(ico2)*oxyco2(1))
coefe(ih2o) = wmole(ih2o)*oxyh2o(1) &
coefe(ico2) = wmole(ico2)*oxyco2(1) &
coefe(in2) = 1.d0-coefe(io2)-coefe(ih2o)-coefe(ico2)
mode = -1
call cs_fuel_htconvers1(mode,h1init,coefe,t1init)
call field_get_val_s(ivarfl(isca(iscalt)), cvar_scalt)
do iel = 1, ncel
cvar_scalt(iel) = h1init
enddo
! ------ Transported variables for gaseous mixture
! (passive scalars, variance, reactive species)
call field_get_val_s(ivarfl(isca(ifvap)), cvar_fvap)
call field_get_val_s(ivarfl(isca(if7m)), cvar_f7m)
call field_get_val_s(ivarfl(isca(ifvp2m)), cvar_fvp2m)
call field_get_val_s(ivarfl(isca(iyco2)), cvar_yco2)
call field_get_val_s(ivarfl(isca(iyhcn)), cvar_yhcn)
call field_get_val_s(ivarfl(isca(iyno)), cvar_yno)
call field_get_val_s(ivarfl(isca(ihox)), cvar_hox)
do iel = 1, ncel
cvar_fvap(iel) = 0.d0
cvar_f7m(iel) = zero
cvar_fvp2m(iel) = zero
if (ieqco2 .ge. 1) then
ioxy = 1
wmo2 = wmole(io2)
wmco2 = wmole(ico2)
wmh2o = wmole(ih2o)
wmn2 = wmole(in2)
dmas = ( oxyo2(ioxy)*wmo2 +oxyn2(ioxy)*wmn2 &
+oxyh2o(ioxy)*wmh2o+oxyco2(ioxy)*wmco2 )
cvar_yco2(iel) = oxyco2(ioxy)*wmco2/dmas
endif
if (ieqnox .eq. 1) then
cvar_yhcn(iel) = zero
cvar_yno(iel) = zero
cvar_hox(iel) = h1init
endif
enddo
endif
Finalization
There is no work array in this subroutine, thus nothing to do.
