Compressible example
Local variables to be added
The following local variables need to be defined for the examples in this section:
integer, allocatable, dimension(:) :: lstelt
integer iel
integer iscal, imodif
double precision, allocatable, dimension(:) :: w1, w2, w3, w4
double precision, dimension(:), pointer :: cpro_rom
double precision, dimension(:,:), pointer :: cvar_vel
double precision, dimension(:), pointer :: cvar_pr
double precision, dimension(:), pointer :: cvar_scal, cvar_tempk, cvar_energ
Allocation
Before user initialization, work arrays must be allocated.
Initialization
The following initialization block needs to be added for the following examples:
if ( isuite.eq.0 ) then
! --- Velocity components
do iel = 1, ncel
cvar_vel(1,iel) = 0.d0
cvar_vel(2,iel) = 0.d0
cvar_vel(3,iel) = 0.d0
enddo
! --- User defined scalars
! If there are user defined scalars
if(nscaus.gt.0) then
! For each scalar
do iscal = 1, nscaus
! If the scalar is associated to the considered phase iphas
! if(iphsca(iscal).eq.iphas) then
call field_get_val_s(ivarfl(isca(iscal)), cvar_scal)
! Initialize each cell value
do iel = 1, ncel
cvar_scal(iel) = 0.d0
enddo
! endif
enddo
endif
! --- Pressure, Density, Temperature, Total Energy
! Only 2 out of these 4 variables are independent: one may choose to
! initialize any pair of variables picked out of these 4, except
! (Temperature-Energy). The remaining 2 variables will be deduced
! automatically.
! Initialize 2 and only 2 variables
! To do so, set iutile=1 for each of the 2 selected variables
! and iutile=0 for each of the 2 others
! In the example provided below, Pressure and Temperature are
! initialized.
! ithvar indicates which variables have been set:
! it is completed automatically for each variable and
! it must not be modified.
! 1. Pressure (Pa)
if(.true.) then
ithvar = ithvar*2
do iel = 1, ncel
cvar_pr(iel) = p0
enddo
endif
! 2. Density (kg.m-3)
if(.false.) then
ithvar = ithvar*3
do iel = 1, ncel
cpro_rom(iel) = ro0
enddo
endif
! 3. Temperature (K -- Warning: Kelvin)
if(.true.) then
ithvar = ithvar*5
call field_get_val_s(ivarfl(isca(itempk)), cvar_tempk)
do iel = 1, ncel
cvar_tempk(iel) = t0
enddo
endif
! 4. Total Energy (J/kg)
if(.false.) then
ithvar = ithvar*7
call field_get_val_s(ivarfl(isca(ienerg)), cvar_energ)
do iel = 1, ncel
cvar_energ(iel) = cv0*t0
enddo
endif
endif
Finalization
At the end of the subroutine, it is recommended to deallocate the work arrays:
deallocate(lstelt) ! temporary array for cells selection
deallocate(w1, w2, w3, w4)
