Atmospheric example
Atmospheric example
Local variables to be added
The following local variables need to be defined for the examples in this section:
integer iel
double precision d2s3
double precision zent,xuent,xvent,xkent,xeent,tpent
double precision, dimension(:,:), pointer :: cvar_vel
integer, allocatable, dimension(:) :: lstelt
double precision, dimension(:), pointer :: cvar_k, cvar_ep, cvar_phi, cvar_fb
double precision, dimension(:), pointer :: cvar_omg, cvar_nusa
double precision, dimension(:), pointer :: cvar_r11, cvar_r22, cvar_r33
double precision, dimension(:), pointer :: cvar_r12, cvar_r13, cvar_r23
double precision, dimension(:), pointer :: cvar_scalt
Allocation
Before user initialization, work arrays lstelt must be allocated, like in basic example.
Initialization
The following initialization block needs to be added for the following examples:
! Map field arrays
call field_get_val_v(ivarfl(iu), cvar_vel)
allocate(lstelt(ncel)) ! temporary array for cells selection
d2s3 = 2.d0/3.d0
! Initialize variables using an input meteo profile
! (only if we are not doing a restart)
if (isuite.eq.0) then
if (itytur.eq.2) then
call field_get_val_s(ivarfl(ik), cvar_k)
call field_get_val_s(ivarfl(iep), cvar_ep)
elseif (itytur.eq.3) then
call field_get_val_s(ivarfl(ir11), cvar_r11)
call field_get_val_s(ivarfl(ir22), cvar_r22)
call field_get_val_s(ivarfl(ir33), cvar_r33)
call field_get_val_s(ivarfl(ir12), cvar_r12)
call field_get_val_s(ivarfl(ir13), cvar_r13)
call field_get_val_s(ivarfl(ir23), cvar_r23)
elseif (iturb.eq.50) then
call field_get_val_s(ivarfl(iphi), cvar_phi)
call field_get_val_s(ivarfl(ifb), cvar_fb)
elseif (iturb.eq.60) then
call field_get_val_s(ivarfl(iomg), cvar_omg)
elseif (iturb.eq.70) then
call field_get_val_s(ivarfl(inusa), cvar_nusa)
endif
do iel = 1, ncel
zent = xyzcen(3,iel)
call intprf &
(nbmetd, nbmetm, &
zdmet, tmmet, umet , zent , ttcabs, xuent )
call intprf &
(nbmetd, nbmetm, &
zdmet, tmmet, vmet , zent , ttcabs, xvent )
call intprf &
(nbmetd, nbmetm, &
zdmet, tmmet, ekmet, zent , ttcabs, xkent )
call intprf &
(nbmetd, nbmetm, &
zdmet, tmmet, epmet, zent , ttcabs, xeent )
cvar_vel(1,iel) = xuent
cvar_vel(2,iel) = xvent
cvar_vel(3,iel) = 0.d0
! ITYTUR est un indicateur qui vaut ITURB/10
cvar_k(iel) = xkent
cvar_ep(iel) = xeent
cvar_r11(iel) = d2s3*xkent
cvar_r22(iel) = d2s3*xkent
cvar_r33(iel) = d2s3*xkent
cvar_r12(iel) = 0.d0
cvar_r13(iel) = 0.d0
cvar_r23(iel) = 0.d0
cvar_k(iel) = xkent
cvar_phi(iel) = d2s3
cvar_fb(iel) = 0.d0
cvar_k(iel) = xkent
cvar_omg(iel) = xeent/cmu/xkent
cvar_nusa(iel) = cmu*xkent**2/xeent
endif
if (iscalt.ge.0) then
! On suppose que le scalaire est la temperature potentielle :
call intprf &
(nbmett, nbmetm, &
ztmet, tmmet, tpmet, zent , ttcabs, tpent )
call field_get_val_s(ivarfl(isca(iscalt)), cvar_scalt)
cvar_scalt(iel) = tpent
endif
enddo
endif
Finalization
At the end of the subroutine, it is recommended to deallocate the work array lstelt, like in basic example.
