| interface | parcmx |
| | Compute the global maximum of an integer in case of parellism. More...
| interface | parmax |
| | Compute the global maximum of a real number in case of parellism. More...
| interface | parcmn |
| | Compute the global minimum of an integer in case of parellism. More...
| interface | parmin |
| | Compute the global minimum of a real number in case of parellism. More...
| interface | parcpt |
| | Compute the global sum of an integer in case of parellism. More...
| interface | parsom |
| | Compute the global sum of a real number in case of parellism. More...
| interface | parimx |
| | Compute the global maxima of an array of integers in case of parellism. More...
| interface | parrmx |
| | Compute the global maxima of an array of real numbers in case of parellism. More...
| interface | parimn |
| | Compute the global minima of an array of integers in case of parellism. More...
| interface | parrmn |
| | Compute the global minima of an array of real numbers in case of parellism. More...
| interface | parism |
| | Compute the global sums of an array of integers in case of parellism. More...
| interface | parrsm |
| | Compute the global sums of an array of real numbers in case of parellism. More...
| interface | parall_bcast_i |
| | Broadcast an integer in case of parellism. More...
| interface | parall_bcast_r |
| | Broadcast a real number in case of parellism. More...
| interface | parbci |
| | Broadcast an array of integers in case of parellism. More...
| interface | parbcr |
| | Broadcast an array of real numbers in case of parellism. More...
| interface | parmxl |
| | Maximum value of a real and the value of related array on all default communicator processes. More...
| interface | parmnl |
| | Minimum value of a real and the value of related array on all default communicator processes. More...
| interface | parfpt |
| | Given an (id, rank, value) tuple, return the local id, rank, and value corresponding to the global minimum value. More...
| interface | cs_parall_allgather_r |
| | Build a global array from each local array in each domain. More...
| interface | parbar |
| | Set a barrier on all default communicator processes. More...
Module for basic MPI and OpenMP parallelism-related values.
