| integer, save | ipr |
| integer, save | iu |
| integer, save | iv |
| integer, save | iw |
| integer, save | ivolf2 |
| integer, save | ik |
| integer, save | iep |
| integer, save | ir11 |
| integer, save | ir22 |
| integer, save | ir33 |
| integer, save | ir12 |
| integer, save | ir23 |
| integer, save | ir13 |
| integer, save | irij |
| integer, save | iphi |
| integer, save | ifb |
| integer, save | ial |
| integer, save | iomg |
| integer, save | inusa |
| integer, dimension(nscamx), save | isca |
| integer, dimension(nscamx), save | iscapp |
| integer, save | nscaus |
| integer, save | nscapp |
| integer(c_int), pointer, save | nscasp |
| integer, save | iuma |
| integer, save | ivma |
| integer, save | iwma |
| integer, save | irom |
| | Density at the current time step (equal to icrom, kept for compatibility) More...
| integer, save | iviscl |
| | dynamic molecular viscosity (in kg/(m.s)) More...
| integer, save | ivisct |
| | dynamic turbulent viscosity More...
| integer, dimension(nestmx), save | iestim |
| | error estimator for Navier-Stokes More...
| integer, save | kimasf |
| | interior and boundary convective mass flux key ids of the variables More...
| integer, save | kbmasf |
| integer, save | kvisl0 |
| | constant diffusivity field id key for scalars More...
| integer, save | kivisl |
| | variable diffusivity field id key for scalars More...
| integer, save | kromsl |
| | variable density field id key for scalars More...
| integer, save | kstprv |
| | source terms at previous time step for 2nd order More...
| integer, save | kst |
| | source terms at the current time step (used for limiters) More...
| integer, save | ksigmas |
| | turbulent schmidt key for scalars More...
| integer, dimension(nvarmx), save | ifluaa |
| | convective mass flux of the variables at the previous time-step More...
| integer, save | icrom |
| | cell density field ids of the variables More...
| integer, save | ibrom |
| | boundary density field ids of the variables More...
| integer, save | ipori |
| | field ids of the cell porosity More...
| integer, save | iporf |
| integer, save | ismago |
| | dynamic constant of Smagorinsky More...
| integer, save | ivsten |
| | field ids of the anisotropic viscosity More...
| integer, save | ivstes |
| integer, save | icour |
| | Courant number. More...
| integer, save | ifour |
| | Fourier number. More...
| integer, save | iprtot |
| | Total pressure at cell centers . More...
| integer, save | ivisma |
| | Mesh velocity viscosity for the ALE module. More...
| integer, dimension(nscamx), save | iustdy |
| | pointer for dilatation source terms More...
| integer, save | itsrho |
| | pointer for global dilatation source terms More...
| integer, save | ibeta |
| | pointer for thermal expansion coefficient More...
| integer, save | iddgas |
| | pointer for deduced mass fraction in case of gas mix More...
| integer, save | igmxml |
| | pointer for gas mix molar mass More...
| integer, save | iforbr |
| | field id of the stresses at boundary (if post-processed) More...
| integer, save | iyplbr |
| | field id of at boundary (if post-processed) More...
| integer, save | itempb |
| | field id of temperature at boundary More...
| integer, save | is2kw |
| | field id of the square of the norm of the deviatoric part of the deformation rate tensor ( ). Field defined only with the (SST) turbulence model More...
| integer, save | idivukw |
| | field id of the divergence of the velocity. More precisely, it is the trace of the velocity gradient (and not a finite volume divergence term). In the cell iel, is given by divukw(iel1). This array is defined only with the SST turbulence model (because in this case it may be calculated at the same time as ) More...
| integer, save | istraio |
| | field id of the strain rate tensor at the previous time step More...
| integer, save | kwgrec |
| | Weighting for gradient calculation on variables. More...
| integer, dimension(nvarmx), save | ivarfl |
| | Field id for variable i. More...
| integer, save | idtten |
| | Field id for the dttens tensor. More...
Module for variable numbering.
