fvm_writer_priv.h
1 #ifndef __FVM_WRITER_PRIV_H__
2 #define __FVM_WRITER_PRIV_H__
5  * Private types for mesh and field writers
30 #include "cs_defs.h"
33  * Local headers
36 #include "cs_timer.h"
38 #include "fvm_defs.h"
39 #include "fvm_nodal.h"
40 #include "fvm_writer.h"
45
46 /*=============================================================================
47  * Macro definitions
49
50 /*
51  * Writer format implementation and functionality info
52  */
53
54 #define FVM_WRITER_FORMAT_USE_EXTERNAL (1 << 0)
55
56 #define FVM_WRITER_FORMAT_HAS_POLYGON (1 << 1)
57 #define FVM_WRITER_FORMAT_HAS_POLYHEDRON (1 << 2)
58
59 #define FVM_WRITER_FORMAT_SEPARATE_MESHES (1 << 3)
60
61 #define FVM_WRITER_FORMAT_NAME_IS_OPTIONAL (1 << 4)
62
63 /*============================================================================
64  * Type definitions
65  *============================================================================*/
66
67 /*----------------------------------------------------------------------------
68  * Function pointer types
69  *----------------------------------------------------------------------------*/
70
71 typedef int
73
74 typedef const char *
75 (fvm_writer_version_string_t)(int string_index,
76  int compile_time_version);
77
78 #if defined(HAVE_MPI)
79
80 typedef void *
81 (fvm_writer_init_t) (const char *name,
82  const char *path,
83  const char *options,
84  fvm_writer_time_dep_t time_dependency,
85  MPI_Comm comm);
86
87 #else
88
89 typedef void *
90 (fvm_writer_init_t) (const char *name,
91  const char *path,
92  const char *options,
93  fvm_writer_time_dep_t time_dependency);
94
95 #endif /* defined(HAVE_MPI) */
96
97 typedef void *
98 (fvm_writer_finalize_t) (void *this_writer);
99
100 typedef void
101 (fvm_writer_set_mesh_time_t) (void *this_writer,
102  int time_step,
103  double time_value);
104
105 typedef int
106 (fvm_writer_needs_tesselation_t) (void *this_writer,
107  const fvm_nodal_t *mesh,
108  fvm_element_t element_type);
109
110 typedef void
111 (fvm_writer_export_nodal_t) (void *this_writer,
112  const fvm_nodal_t *mesh);
113
114 typedef void
115 (fvm_writer_export_field_t) (void *this_writer,
116  const fvm_nodal_t *mesh,
117  const char *name,
118  fvm_writer_var_loc_t location,
119  int dimension,
120  cs_interlace_t interlace,
121  int n_parent_lists,
122  const cs_lnum_t parent_num_shift[],
123  cs_datatype_t datatype,
124  int time_step,
125  double time_value,
126  const void *const field_values[]);
127
128 typedef void
129 (fvm_writer_flush_t) (void *this_writer);
130
131 /*----------------------------------------------------------------------------
132  * Format information structure
133  *----------------------------------------------------------------------------*/
134
135 typedef struct {
136
137  char name[32]; /* Format name */
138  char version[16]; /* Format version (if defined) */
139  int info_mask; /* Additional format info */
140  fvm_writer_time_dep_t max_time_dep; /* Maximum time dependency level
141  possible with this format */
142
143  int dl_count; /* Number of writers using the
144  dynamically loadable library
145  for this format, if relevant */
146  void *dl_lib; /* Pointer to dynamically loadable
147  library, if used */
148  const char *dl_name; /* Prefix for name of dynamically
149  loadable library, or NULL */
150  const char *dl_prefix; /* Prefix for exported symbols of
151  dynamically loadable library,
152  or NULL */
153
163
165
166 /*----------------------------------------------------------------------------
167  * Structure defining a writer definition
168  *----------------------------------------------------------------------------*/
169
171
172  char *name; /* Writer name */
173  fvm_writer_format_t *format; /* Output format */
174  char *options; /* Output options */
175  char *path; /* Output path */
176  fvm_writer_time_dep_t time_dep; /* Geometry time dependency */
177  int n_format_writers; /* number of actual writers */
178  void **format_writer; /* Format-specific writers */
179  char **mesh_names; /* List of mesh names if one
180  writer per mesh is required */
181
182  cs_timer_counter_t mesh_time; /* Meshes output timer */
183  cs_timer_counter_t field_time; /* Fields output timer */
184  cs_timer_counter_t flush_time; /* output "completion" timer */
185
186 };
187
188 /*----------------------------------------------------------------------------*/
189
191
192 #endif /* __FVM_WRITER_PRIV_H__ */
void() fvm_writer_set_mesh_time_t(void *this_writer, int time_step, double time_value)
Definition: fvm_writer_priv.h:101
cs_datatype_t
Definition: cs_defs.h:260
fvm_writer_needs_tesselation_t * needs_tesselation_func
Definition: fvm_writer_priv.h:159
fvm_writer_set_mesh_time_t * set_mesh_time_func
Definition: fvm_writer_priv.h:158
void *() fvm_writer_init_t(const char *name, const char *path, const char *options, fvm_writer_time_dep_t time_dependency)
Definition: fvm_writer_priv.h:90
fvm_writer_finalize_t * finalize_func
Definition: fvm_writer_priv.h:157
Definition: fvm_writer.h:69
int dl_count
Definition: fvm_writer_priv.h:143
cs_interlace_t
Definition: cs_defs.h:439
Definition: fvm_writer_priv.h:135
Definition: fvm_writer_priv.h:170
Definition: cs_defs.h:467
Definition: fvm_writer_priv.h:184
int() fvm_writer_n_version_strings_t(void)
Definition: fvm_writer_priv.h:72
int() fvm_writer_needs_tesselation_t(void *this_writer, const fvm_nodal_t *mesh, fvm_element_t element_type)
Definition: fvm_writer_priv.h:106
fvm_writer_version_string_t * version_string_func
Definition: fvm_writer_priv.h:155
const char * dl_name
Definition: fvm_writer_priv.h:148
Definition: fvm_writer.h:57
Definition: fvm_writer_priv.h:140
fvm_writer_export_field_t * export_field_func
Definition: fvm_writer_priv.h:161
void() fvm_writer_flush_t(void *this_writer)
Definition: fvm_writer_priv.h:129
char * options
Definition: fvm_writer_priv.h:174
Definition: fvm_writer_priv.h:177
fvm_element_t
Definition: fvm_defs.h:48
void() fvm_writer_export_nodal_t(void *this_writer, const fvm_nodal_t *mesh)
Definition: fvm_writer_priv.h:111
int info_mask
Definition: fvm_writer_priv.h:139
Definition: fvm_writer_priv.h:176
const char * dl_prefix
Definition: fvm_writer_priv.h:150
void ** format_writer
Definition: fvm_writer_priv.h:178
void *() fvm_writer_finalize_t(void *this_writer)
Definition: fvm_writer_priv.h:98
fvm_writer_export_nodal_t * export_nodal_func
Definition: fvm_writer_priv.h:160
Definition: cs_defs.h:298
fvm_writer_format_t * format
Definition: fvm_writer_priv.h:173
fvm_writer_flush_t * flush_func
Definition: fvm_writer_priv.h:162
Definition: cs_defs.h:468
char ** mesh_names
Definition: fvm_writer_priv.h:179
fvm_writer_init_t * init_func
Definition: fvm_writer_priv.h:156
char * name
Definition: fvm_writer_priv.h:172
void() fvm_writer_export_field_t(void *this_writer, const fvm_nodal_t *mesh, const char *name, fvm_writer_var_loc_t location, int dimension, cs_interlace_t interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, int time_step, double time_value, const void *const field_values[])
Definition: fvm_writer_priv.h:115
const char *() fvm_writer_version_string_t(int string_index, int compile_time_version)
Definition: fvm_writer_priv.h:75
Definition: fvm_writer_priv.h:182
char * path
Definition: fvm_writer_priv.h:175
void * dl_lib
Definition: fvm_writer_priv.h:146
fvm_writer_n_version_strings_t * n_version_strings_func
Definition: fvm_writer_priv.h:154
Definition: fvm_writer_priv.h:183
Definition: mesh.f90:26
Definition: cs_timer.h:57
