fvm_selector.h
1 #ifndef __FVM_SELECTOR_H__
2 #define __FVM_SELECTOR_H__
5  * Mechanism for entity selection based on groups or attributes
30 #include "cs_defs.h"
33  * Local headers
36 #include "fvm_defs.h"
37 #include "fvm_group.h"
38
44  * Macro definitions
46
48  * Type definitions
50
51 typedef struct _fvm_selector_t fvm_selector_t;
52
53 /*=============================================================================
54  * Public function prototypes
56
58  * Creation of a selector object.
59  *
60  * parameters:
61  * dim <-- spatial dimension (coordinates and normals)
62  * n_elements <-- number of selectable elements
63  * group_class_set <-- pointer to group class set definition
64  * group_class_id <-- group class id associated with each element
65  * (size: n_elements)
66  * group_class_id_base; <-- Starting group class id base (usually 0 or 1)
67  * coords <-- coordinates (interlaced) associated with each
68  * element, whether vertex, face or cell center, ...
69  * (size: n_elements * dim)
70  * normals <-- normals (interlaced) associated with each element
71  * if applicable (such as for face normals), or NULL
72  *
73  * returns:
74  * pointer to new selector
75  *----------------------------------------------------------------------------*/
76
78 fvm_selector_create(int dim,
79  cs_lnum_t n_elements,
80  const fvm_group_class_set_t *group_class_set,
81  const int group_class_id[],
82  int group_class_id_base,
83  const double coords[],
84  const double normals[]);
85
87  * Destruction of a selector structure.
88  *
89  * parameters:
90  * this_selector <-> selector to destroy
91  *
92  * returns:
93  * NULL pointer
94  *----------------------------------------------------------------------------*/
95
97 fvm_selector_destroy(fvm_selector_t *this_selector);
98
99 /*----------------------------------------------------------------------------
100  * Define the list of the elements verifying the criteria described
101  * by a character string
102  *
103  * The selected_element[] array must be pre-allocated, and be of sufficient
104  * size to contain all elements associated with the selector.
105  *
106  * parameters:
107  * this_selector <-> pointer to selector
108  * str <-- string defining selection criteria
109  * elt_id_base <-- element id base (usually 0 or 1)
110  * n_selected_elements <-- number of elements selected
111  * selected_elements <-> selected elements list (1 to n numbering)
112  *
113  * returns:
114  * criteria id associated by selector with str
115  *----------------------------------------------------------------------------*/
116
117 int
119  const char *str,
120  cs_lnum_t elt_id_base,
121  cs_lnum_t *n_selected_elements,
122  cs_lnum_t *selected_elements);
123
124 /*----------------------------------------------------------------------------
125  * Define the list of group classes verifying the criteria described
126  * by a character string.
127  *
128  * The selected_gc[] array must be pre-allocated, and be of sufficient
129  * size to contain all elements associated with the selector.
130  *
131  * parameters:
132  * this_selector <-> pointer to selector
133  * str <-- string defining selection criteria
134  * n_selected_gcs <-- number of group classes selected
135  * selected_gcs <-> selected group class list (0 to n numbering,
136  * as group class "zero" may exist)
137  *
138  * returns:
139  * criteria id associated by selector with str
140  *----------------------------------------------------------------------------*/
141
142 int
144  const char *str,
145  int *n_selected_gcs,
146  int selected_gcs[]);
147
148 /*----------------------------------------------------------------------------
149  * Return the number of operands associated with a selection criteria
150  * which are missing in the selector's associated group class set.
151  *
152  * parameters:
153  * this_selector <-- pointer to selector
154  * criteria_id <-- id of criteria returned by fvm_selector_get_list()
155  *
156  * returns:
157  * number of missing operands
158  *----------------------------------------------------------------------------*/
159
160 int
161 fvm_selector_n_missing(const fvm_selector_t *this_selector,
162  int criteria_id);
163
164 /*----------------------------------------------------------------------------
165  * Return a pointer to the name of an of operand associated with a selection
166  * criteria which is missing in the selector's associated group class set.
167  *
168  * parameters:
169  * this_selector <-- pointer to selector
170  * criteria_id <-- id of criteria returned by fvm_selector_get_list()
171  * missing_id <-- id of missing operand for this criteria
172  *
173  * returns:
174  * pointer to name of missing operand
175  *----------------------------------------------------------------------------*/
176
177 const char *
178 fvm_selector_get_missing(const fvm_selector_t *this_selector,
179  int criteria_id,
180  int missing_id);
181
182 /*----------------------------------------------------------------------------
183  * Get statistics on selector usage
184  *
185  * parameters:
186  * this_selector <-- pointer to selector
187  * n_evals <-> number of evaluations, or NULL
188  * eval_wtime <-> evaluation wall-clock time, or NULL
189  *----------------------------------------------------------------------------*/
190
191 void
192 fvm_selector_get_stats(const fvm_selector_t *this_selector,
193  int *n_evals,
194  double *eval_wtime);
195
196 /*----------------------------------------------------------------------------
197  * Dump the contents of a selector structure in human readable form
198  *
199  * parameters:
200  * this_selector <-- pointer to selector
201  *----------------------------------------------------------------------------*/
202
203 void
204 fvm_selector_dump(const fvm_selector_t *this_selector);
205
206 /*----------------------------------------------------------------------------*/
207
209
210 #endif /* __FVM_SELECTOR_H__ */
fvm_selector_t * fvm_selector_destroy(fvm_selector_t *this_selector)
Definition: fvm_selector.c:863
Definition: cs_defs.h:467
Definition: fvm_selector.h:51
int fvm_selector_get_list(fvm_selector_t *this_selector, const char *str, cs_lnum_t elt_id_base, cs_lnum_t *n_selected_elements, cs_lnum_t *selected_elements)
Definition: fvm_selector.c:929
int fvm_selector_n_missing(const fvm_selector_t *this_selector, int criteria_id)
Definition: fvm_selector.c:1124
int fvm_selector_get_gc_list(fvm_selector_t *this_selector, const char *str, int *n_selected_gcs, int selected_gcs[])
Definition: fvm_selector.c:1060
fvm_selector_t * fvm_selector_create(int dim, cs_lnum_t n_elements, const fvm_group_class_set_t *group_class_set, const int group_class_id[], int group_class_id_base, const double coords[], const double normals[])
Definition: fvm_selector.c:763
void fvm_selector_dump(const fvm_selector_t *this_selector)
Definition: fvm_selector.c:1205
Definition: cs_defs.h:298
Definition: cs_defs.h:468
Definition: fvm_group.h:60
void fvm_selector_get_stats(const fvm_selector_t *this_selector, int *n_evals, double *eval_wtime)
Definition: fvm_selector.c:1185
const char * fvm_selector_get_missing(const fvm_selector_t *this_selector, int criteria_id, int missing_id)
Definition: fvm_selector.c:1156
