fvm_point_location.h
1 #ifndef __FVM_POINT_LOCATION_H__
2 #define __FVM_POINT_LOCATION_H__
5  * Locate local points in a nodal representation associated with a mesh
30 #include "cs_defs.h"
33  * Local headers
36 #include "fvm_defs.h"
37 #include "fvm_nodal.h"
38
44  * Macro definitions
46
48  * Type definitions
50
51 /*=============================================================================
52  * Static global variables
54
56  * Public function prototypes
58
59 /*----------------------------------------------------------------------------
60  * Find elements in a given nodal mesh containing points: updates the
61  * location[] and distance[] arrays associated with a set of points
62  * for points that are in an element of this mesh, or closer to one
63  * than to previously encountered elements.
64  *
65  * parameters:
66  * this_nodal <-- pointer to nodal mesh representation structure
67  * tolerance_base <-- associated base tolerance (used for bounding
68  * box check only, not for location test)
69  * tolerance_multiplier <-- associated fraction of element bounding boxes
70  * added to tolerance
71  * locate_on_parents <-- location relative to parent element numbers if 1,
72  * id of element + 1 in concatenated sections of
73  * same element dimension if 0
74  * n_points <-- number of points to locate
75  * point_tag <-- optional point tag
76  * point_coords <-- point coordinates
77  * location <-> number of element containing or closest to each
78  * point (size: n_points)
79  * distance <-> distance from point to element indicated by
80  * location[]: < 0 if unlocated, 0 - 1 if inside,
81  * and > 1 if outside a volume element, or absolute
82  * distance to a surface element (size: n_points)
83  *----------------------------------------------------------------------------*/
84
85 void
86 fvm_point_location_nodal(const fvm_nodal_t *this_nodal,
87  float tolerance_base,
88  float tolerance_fraction,
89  int locate_on_parents,
90  cs_lnum_t n_points,
91  const cs_lnum_t *point_tag,
92  const cs_coord_t point_coords[],
93  cs_lnum_t location[],
94  float distance[]);
95
96 /*----------------------------------------------------------------------------
97  * For each point previously located in a element, find among vertices of this
98  * element the closest vertex relative to this point.
99  *
100  * As input, located_ent_num is an array with a numbering not using a parent
101  * numbering. As output, located_ent_num may use a parent numbering
102  * according to the value of locate_on_parents.
103  *
104  * The located_vtx_num output is also determined relative to the
105  * locate_on_parents option.
106  *
107  * parameters:
108  * this_nodal <-- pointer to nodal mesh representation structure
109  * locate_on_parents <-- location relative to parent element numbers if 1,
110  * id of element + 1 in concatenated sections of
111  * same element dimension if 0
112  * n_points <-- number of points to locate
113  * point_coords <-- point coordinates
114  * located_ent_num <-> input: list of elements (cells or faces according
115  * to max entity dim) where points have been
116  * initially located or not (size: n_points)
117  * output: possibly modified by parent numbering
118  * located_vtx_num <-> output: list of vertices closest to each point
119  *----------------------------------------------------------------------------*/
120
121 void
122 fvm_point_location_closest_vertex(const fvm_nodal_t *this_nodal,
123  int locate_on_parents,
124  cs_lnum_t n_points,
125  const cs_coord_t point_coords[],
126  cs_lnum_t located_ent_num[],
127  cs_lnum_t located_vtx_num[]);
128
129 /*----------------------------------------------------------------------------*/
130
132
133 #endif /* __FVM_POINT_LOCATION_H__ */
Definition: cs_defs.h:467
void fvm_point_location_nodal(const fvm_nodal_t *this_nodal, float tolerance_base, float tolerance_fraction, int locate_on_parents, cs_lnum_t n_points, const cs_lnum_t *point_tag, const cs_coord_t point_coords[], cs_lnum_t location[], float distance[])
Definition: fvm_point_location.c:3254
double cs_coord_t
Definition: cs_defs.h:299
Definition: cs_defs.h:298
Definition: cs_defs.h:468
void fvm_point_location_closest_vertex(const fvm_nodal_t *this_nodal, int locate_on_parents, cs_lnum_t n_points, const cs_coord_t point_coords[], cs_lnum_t located_ent_num[], cs_lnum_t located_vtx_num[])
Definition: fvm_point_location.c:3418
