fvm_nodal_order.h
1 #ifndef __FVM_NODAL_ORDER_H__
2 #define __FVM_NODAL_ORDER_H__
5  * Ordering of nodal mesh entity lists and connectivity
30 #include "cs_defs.h"
33  * Local headers
36 #include "fvm_defs.h"
42 /*=============================================================================
43  * Macro definitions
45
47  * Type definitions
49
50 /*=============================================================================
51  * Static global variables
53
54 /*=============================================================================
55  * Public function prototypes
57
58 /*----------------------------------------------------------------------------
59  * Locally order cells and associated connectivity for a nodal mesh
60  *
61  * parameters:
62  * this_nodal <-- pointer to nodal mesh structure.
63  * parent_global_number <-- global numbers of parent cells (if NULL, a
64  * default 1 to n numbering is considered).
65  *----------------------------------------------------------------------------*/
66
67 void
68 fvm_nodal_order_cells(fvm_nodal_t *this_nodal,
69  const cs_gnum_t parent_global_number[]);
70
71 /*----------------------------------------------------------------------------
72  * Locally order faces and associated connectivity for a nodal mesh
73  *
74  * parameters:
75  * this_nodal <-- pointer to nodal mesh structure.
76  * parent_global_number <-- global numbers of parent faces (if NULL, a
77  * default 1 to n numbering is considered).
78  *----------------------------------------------------------------------------*/
79
80 void
81 fvm_nodal_order_faces(fvm_nodal_t *this_nodal,
82  const cs_gnum_t parent_global_number[]);
83
84 /*----------------------------------------------------------------------------
85  * Locally order vertices and update connectivity for a nodal mesh
86  *
87  * parameters:
88  * this_nodal <-- pointer to nodal mesh structure.
89  * parent_global_number <-- global numbers of parent vertices (if NULL, a
90  * default 1 to n numbering is considered).
91  *----------------------------------------------------------------------------*/
92
93 void
94 fvm_nodal_order_vertices(fvm_nodal_t *this_nodal,
95  const cs_gnum_t parent_global_number[]);
96
98
100
101 #endif /* __FVM_NODAL_ORDER_H__ */
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:286
void fvm_nodal_order_faces(fvm_nodal_t *this_nodal, const cs_gnum_t parent_global_number[])
Definition: fvm_nodal_order.c:347
Definition: cs_defs.h:467
void fvm_nodal_order_cells(fvm_nodal_t *this_nodal, const cs_gnum_t parent_global_number[])
Definition: fvm_nodal_order.c:275
Definition: cs_defs.h:468
void fvm_nodal_order_vertices(fvm_nodal_t *this_nodal, const cs_gnum_t parent_global_number[])
Definition: fvm_nodal_order.c:419
