fvm_box_tree.h
1 #ifndef __FVM_BOX_TREE_H__
2 #define __FVM_BOX_TREE_H__
5  * Search octrees and quadtrees of boxes.
30 #include "cs_defs.h"
36 #include <stdio.h>
39  * Local headers
42 #include "fvm_box.h"
44 /*----------------------------------------------------------------------------*/
45
49  * Macro definitions
51
53  * Type definitions
55
56 typedef struct _fvm_box_tree_t fvm_box_tree_t;
57
58 typedef enum {
59
60  FVM_BOX_TREE_ASYNC_LEVEL, /* Boxes are placed according to tree parameters,
61  and potentially at different levels */
62  FVM_BOX_TREE_SYNC_LEVEL /* All boxes are placed for all ranks at the
63  same level */
64
66
67 /*============================================================================
68  * Public function definitions
69  *============================================================================*/
70
71 /*----------------------------------------------------------------------------
72  * Create a fvm_box_tree_t structure and initialize it.
73  *
74  * parameters:
75  * max_level <-- max possible level
76  * threshold <-- max number of boxes linked to an octant if
77  * max_level is not reached
78  * max_box_ratio <-- max n_linked_boxes / n_boxes ratio
79  *
80  * returns:
81  * pointer to an empty fvm_box_tree_t structure.
82  *----------------------------------------------------------------------------*/
83
85 fvm_box_tree_create(int max_level,
86  int threshold,
87  float max_box_ratio);
88
89 /*----------------------------------------------------------------------------
90  * Destroy a fvm_box_tree_t structure.
91  *
92  * parameters:
93  * bt <-- pointer to pointer to fvm_box_tree_t structure to destroy
94  *----------------------------------------------------------------------------*/
95
96 void
98
99 /*----------------------------------------------------------------------------
100  * Get the deepest level allowed by the tree structure.
101  *
102  * parameters:
103  * bt <-- pointer to fvm_box_tree_t structure.
104  *
105  * returns:
106  * deepest allowed level of the tree
107  *----------------------------------------------------------------------------*/
108
109 int
111
112 /*----------------------------------------------------------------------------
113  * Assign a set of boxes to an empty fvm_box_tree_t structure.
114  *
115  * The box tree structure must have been created using to fvm_tree_create().
116  *
117  * The depth of the tree is adjusted so that a maximum of max_n_elts boxes
118  * will be assigned to each leaf, unless this would require going beyond
119  * the tree's maximum level.
120  *
121  * If max_level = -1, the highest level reachable is FVM_TREE_MAX_LEVEL but
122  * there is no defined target level.
123  *
124  * parameters:
125  * bt <-> pointer to fvm_box_tree_t structure.
126  * boxes <-- pointer to the associated box set structure
127  * build_type <-- layout variant for building the tree structure
128  *----------------------------------------------------------------------------*/
129
130 void
132  const fvm_box_set_t *boxes,
133  fvm_box_tree_sync_t build_type);
134
135 #if defined(HAVE_MPI)
136
137 /*----------------------------------------------------------------------------
138  * Compute an index based on Morton encoding to ensure a good distribution
139  * of boxes among the participating ranks.
140  *
141  * parameters:
142  * bt <-> pointer to fvm_box_tree_t structure.
143  * boxes <-- pointer to the associated box set structure
144  *
145  * returns:
146  * pointer to newly created fvm_box_distrib_t structure.
147  *----------------------------------------------------------------------------*/
148
150 fvm_box_tree_get_distrib(fvm_box_tree_t *bt,
151  const fvm_box_set_t *boxes);
152
153 #endif /* defined(HAVE_MPI) */
154
155 /*----------------------------------------------------------------------------
156  * Build an indexed list on boxes to list intersections.
157  *
158  * The index and box_g_num arrays are allocated by this function,
159  * and it is the caller's responsibility to free them.
160  *
161  * Upon return, box_index[i] points to the first position in box_g_num
162  * relative to boxes intersecting box i of the boxes set, while
163  * box_g_num contains the global numbers associated with those boxes.
164  *
165  * parameters:
166  * bt <-- pointer to box tree structure to query
167  * boxes <-- pointer to a associated box set
168  * box_index --> pointer to the index array on bounding boxes
169  * box_g_num --> pointer to the list of intersecting bounding boxes
170  *----------------------------------------------------------------------------*/
171
172 void
174  const fvm_box_set_t *boxes,
175  cs_lnum_t *box_index[],
176  cs_gnum_t *box_g_num[]);
177
178 /*----------------------------------------------------------------------------
179  * Get global box tree statistics.
180  *
181  * All fields returned are optional: if their argument is set to NULL,
182  * the corresponding information will not be returned.
183  *
184  * For each field not set to NULL, 3 values are always returned:
185  * the mean on all ranks (rounded to the closest integer), the minimum,
186  * and the maximum value respectively.
187  *
188  * In serial mode, the mean, minimum, and maximum will be identical for most
189  * fields, but all 3 values are returned nonetheless.
190  *
191  * Note that the theoretical memory use includes that of the associated
192  * box set.
193  *
194  * parameters:
195  * bt <-- pointer to box tree structure
196  * depth --> tree depth (max level used)
197  * n_leaves --> number of leaves in the tree
198  * n_boxes --> number of boxes in the tree
199  * n_threshold_leaves --> number of leaves where n_boxes > threshold
200  * n_leaf_boxes --> number of boxes for a leaf
201  * mem_used --> theoretical used memory
202  * mem_allocated --> theoretical allocated memory
203  *
204  * returns:
205  * the spatial dimension associated with the box tree layout (3, 2, or 1)
206  *----------------------------------------------------------------------------*/
207
208 int
210  int depth[3],
211  cs_lnum_t n_leaves[3],
212  cs_lnum_t n_boxes[3],
213  cs_lnum_t n_threshold_leaves[3],
214  cs_lnum_t n_leaf_boxes[3],
215  size_t mem_used[3],
216  size_t mem_allocated[3]);
217
218 /*----------------------------------------------------------------------------
219  * Display local statistics about a fvm_box_tree_t structure.
220  *
221  * parameters:
222  * bt <-- pointer to box tree structure
223  *----------------------------------------------------------------------------*/
224
225 void
227
228 /*----------------------------------------------------------------------------
229  * Dump an fvm_box_tree_t structure.
230  *
231  * parameters:
232  * bt <-- pointer to box tree structure
233  *----------------------------------------------------------------------------*/
234
235 void
237
238 /*----------------------------------------------------------------------------*/
239
241
242 #endif /* __FVM_BOX_TREE_H__ */
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:286
void fvm_box_tree_destroy(fvm_box_tree_t **bt)
Definition: fvm_box_tree.c:2029
fvm_box_tree_t * fvm_box_tree_create(int max_level, int threshold, float max_box_ratio)
Definition: fvm_box_tree.c:1961
void fvm_box_tree_get_intersects(fvm_box_tree_t *bt, const fvm_box_set_t *boxes, cs_lnum_t *box_index[], cs_gnum_t *box_g_num[])
Definition: fvm_box_tree.c:2345
Definition: cs_defs.h:467
int fvm_box_tree_get_stats(const fvm_box_tree_t *bt, int depth[3], cs_lnum_t n_leaves[3], cs_lnum_t n_boxes[3], cs_lnum_t n_threshold_leaves[3], cs_lnum_t n_leaf_boxes[3], size_t mem_used[3], size_t mem_allocated[3])
Definition: fvm_box_tree.c:2430
struct _fvm_box_distrib_t fvm_box_distrib_t
Definition: fvm_box.h:53
Definition: fvm_box_tree.h:60
void fvm_box_tree_dump_statistics(const fvm_box_tree_t *bt)
Definition: fvm_box_tree.c:2601
void fvm_box_tree_set_boxes(fvm_box_tree_t *bt, const fvm_box_set_t *boxes, fvm_box_tree_sync_t build_type)
Definition: fvm_box_tree.c:2079
fvm_box_tree_sync_t
Definition: fvm_box_tree.h:58
Definition: cs_defs.h:298
Definition: cs_defs.h:468
void fvm_box_tree_dump(fvm_box_tree_t *bt)
Definition: fvm_box_tree.c:2739
Definition: fvm_box_tree.h:62
int fvm_box_tree_get_max_level(const fvm_box_tree_t *bt)
Definition: fvm_box_tree.c:2055
Definition: fvm_box_tree.h:56
