Electric arcs examples
Local variables to be added
integer ifac, ii, iel
integer idim
integer izone,iesp
integer ilelt, nlelt
double precision uref2, d2s3
double precision rhomoy, dhy
double precision z1 , z2
integer ipotr, ipoti, f_id, ipotva
character(len=80) :: f_name
integer, allocatable, dimension(:) :: lstelt
double precision, dimension(:), pointer :: bfpro_rom
double precision, dimension(:,:), pointer :: cvara_potva
integer :: keyvar
Example 1
For boundary faces of color 1 assign an inlet and assign a cathode for "electric" variables.
call field_get_val_s(ibrom, bfpro_rom)
call getfbr('1', nlelt, lstelt)
do ilelt = 1, nlelt
ifac = lstelt(ilelt)
itypfb(ifac) = ientre
! Zone Number (from 1 to n)
izone = 1
! Zone localization for a given face
izfppp(ifac) = izone
rcodcl(ifac,iu,1) = 0.d0
rcodcl(ifac,iv,1) = 0.d0
rcodcl(ifac,iw,1) = 0.d0
! Turbulence
if (itytur.eq.2 .or. itytur.eq.3 &
.or. iturb.eq.50 .or. iturb.eq.60 &
.or. iturb.eq.70) then
uref2 = rcodcl(ifac,iu,1)**2 &
+rcodcl(ifac,iv,1)**2 &
+rcodcl(ifac,iw,1)**2
uref2 = max(uref2,1.d-12)
! Turbulence example computed using equations valid for a pipe.
! We will be careful to specify a hydraulic diameter adapted
! to the current inlet.
! We will also be careful if necessary to use a more precise
! formula for the dynamic viscosity use in the calculation of
! the Reynolds number (especially if it is variable, it may be
! useful to take the law from 'cs_user_physical_properties'. Here, we use by default
! the 'viscl0" value.
! Regarding the density, we have acess to its value at boundary
! faces (romb) so this value is the one used here (specifically,
! it is consistent with the processing in 'cs_user_physical_properties', in case of
! variable density)
! Hydraulic diameter
dhy = 0.075d0
rhomoy = bfpro_rom(ifac)
call turbulence_bc_inlet_hyd_diam &
( ifac, uref2, dhy, rhomoy, viscl0, rcodcl )
endif
! --- Handle Scalars
! Enthalpy in J/kg (iscalt)
! On this example we impose the value of the enthalpy
! the arbitrary value of 1.d6 corresponds to a temperature of 2200 Kelvin
! for argon at atmospheric pressure (see dp_ELE)
ii = iscalt
icodcl(ifac,isca(ii)) = 1
rcodcl(ifac,isca(ii),1) = 1.d6
! Electric potential (ipotr)
! (could corresponds also to the real part of the electrical potential if
! Joule Effect by direct conduction)
! In the Cathode example (electric arc applications),
! we impose a constant value of the electrical potential which is zero,
! assuming that the potential is equal to "ipotr + an arbitrary constant"
! (What is important for electric arc is the difference between anode and
! cathode potentials)
icodcl(ifac,ipotr) = 1
rcodcl(ifac,ipotr,1) = 0.d0
! Mass fraction of the (n-1) gas mixture components
if (ngazge .gt. 1) then
do iesp=1,ngazge-1
write(f_name,'(a13,i2.2)') 'esl_fraction_',iesp
call field_get_id(trim(f_name), f_id)
call field_get_key_int(f_id, keyvar, ii)
icodcl(ifac,ii) = 1
rcodcl(ifac,ii,1) = 0.d0
enddo
endif
! Specific model for Joule effect by direct conduction:
! Imaginary part of the potentiel (ipoti) is imposed to zero
if (ippmod(ieljou).ge. 2) then
icodcl(ifac,ipoti) = 1
rcodcl(ifac,ipoti,1) = 0.d0
endif
! Specific model for Electric arc:
! Vector Potential: Zero flux by default beacuse we don't a lot about
! vector potential (what we know, is that A is equal to zero at the infinite)
! All the boundary conditions for A are zero flux, except on some chosen faces
! where we need to impose a value in order to have a stable calculation
! (well defined problem)
! These faces are chosen where we are sure that the electrical current density
! remains very low generally far from the center of the electric arc and from
! the electrodes (see above)
if (ippmod(ielarc).ge.2) then
icodcl(ifac,ipotva ) = 3
rcodcl(ifac,ipotva ,3) = 0.d0
icodcl(ifac,ipotva + 1) = 3
rcodcl(ifac,ipotva + 1,3) = 0.d0
icodcl(ifac,ipotva + 2) = 3
rcodcl(ifac,ipotva + 2,3) = 0.d0
endif
enddo
Example 2
For boundary faces of color 5 assign an free outlet and example of electrode for Joule Effect by direct conduction.
call getfbr('5', nlelt, lstelt)
do ilelt = 1, nlelt
itypfb(ifac) = isolib
izone = 2
! Zone location for a given face
! Enthalpy in J/kg (By default zero flux with ISOLIB)
! Nothing to do
! (Zero flux by defaut with ISOLIB)
! Nothing to do
! Specific model for Joule Effect by direct conduction:
! If you want to make a simulation with an imposed Power PUISIM
! (you want to get PUISIM imposed in cs_user_parameters.c and PUISIM = Amp x Volt)
! you need to impose IELCOR=1 in cs_user_parameters.c
! The boundary conditions will be scaled by COEJOU coefficient
! for example the electrical potential will be multiplied bu COEJOU
! (both real and imaginary part of the electrical potential if needed)
! COEJOU is automatically defined in order that the calculated dissipated power
! by Joule effect (both real and imaginary part if needed) is equal to PUISIM
! At the beginning of the calculation, COEJOU ie equal to 1;
! COEJOU is writing and reading in the result files.
! If you don't want to calculate with by scaling,
! you can impose directly the value.
if (ippmod(ieljou).ge. 1) then
if (ielcor.eq.1) then
rcodcl(ifac,ipotr,1) = 500.d0*coejou
else
endif
endif
rcodcl(ifac,ipoti,1) = sqrt(3.d0)*500.d0*coejou
else
endif
endif
enddo
Example 3
For boundary faces of color 2 assign a free outlet and example of anode for electric arc.
call getfbr('2', nlelt, lstelt)
do ilelt = 1, nlelt
! Zone number (from 1 to n)
izone = 3
! --- Handle scalars
! Enthalpy in J/kg (Zero flux by default with ISOLIB)
! Nothing to do
! Real component of the electrical potential
! For electric arc model,
! * we generally calculate the "electric variables" assuming that the total
! intensity of the electrical current is imposed (COUIMP is the value of
! the imposed total current).
! In that case, you need to impose IELCOR=1 in cs_user_parameters.c
! The "electrical variables" will be scaled by COEPOT coefficient :
! for example the electrical potential will be multiplied by COEPOT,
! Joule effect will be multipied by COEPOT * COEPOT and so on (see cs_user_electric_scaling.c)
! COEJOU is defined in cs_user_electric_scaling.c : different possibilities are described in
! cs_user_electric_scaling.c, depending on the different physics you want to simulate
! (scaling from current, from power, special model for restriking ...)
! The variable DPOT is defined: it corresponds to the electrical potential
! difference between the electrodes (Anode potential - cathode Potential).
! DPOT is calculated in cs_user_electric_scaling.c. DPOT is saved at each time step, and
! for a following calculation
! DPOT is the value of the boundary condition on anode assuming that
! the cathode potential is equel to zero.
! * It is also possible to fix the value of the potential on the anode.
! (for example, 1000 Volts).
if (ippmod(ielarc).ge.1 .and. ielcor .eq.1) then
rcodcl(ifac,ipotr,1) = pot_diff
else
rcodcl(ifac,ipotr,1) = 1000.d0
endif
! zero flux by default with ISOLIB
! nothing to do
! vector Potential
! nothing to do
enddo
Example 4
For boundary faces of color 3 assign a wall and example of potential vector Dirichlet condition
call getfbr('3', nlelt, lstelt)
do ilelt = 1, nlelt
itypfb(ifac) = iparoi
izone = 4
! Wall: zero flow (zero flux for pressure)
! friction for velocities (+ turbulent variables)
! zero flux for scalars
! Enthalpy in J/kg (Zero flux by default)
! Nothing to do
! Zero flux by default
! Nothing to do
! Specific model for Electric arc :
! Vector potential A (Ax, Ay, Az)
! Zero flux by default because we don't a lot about vector potential
! (what we know, is that A is equal to zero at the infinite)
! the electrodes:
! On the following example, we choose to impose a "dirichlet" value for the
! 3 components of A on a small zone of the boundary located near the vertical
! free outlet of the computation domain.
! In this example, the electric arc is at the center of the computational domain,
! located on z axis (near x = 0 and y = 0).
! The x (1st) and y (the 3rd) coordinates are contained between
! -2.5 cm nd 2.5 cm:
! Ax(t, x,y,z) = Ax(t-dt, x=2.5cm, y=2.5cm, z)
! Ay(t, x,y,z) = Ay(t-dt, x=2.5cm, y=2.5cm, z)
! Az(t, x,y,z) = Az(t-dt, x=2.5cm, y=2.5cm, z)
if (cdgfbo(1,ifac) .le. 2.249d-2 .or. &
cdgfbo(1,ifac) .ge. 2.249d-2 .or. &
cdgfbo(3,ifac) .le. -2.249d-2 .or. &
cdgfbo(3,ifac) .ge. 2.249d-2 ) then
call field_get_val_prev_v_by_name('vec_potential', cvara_potva)
iel = ifabor(ifac)
icodcl(ifac,ipotva) = 1
rcodcl(ifac,ipotva,1) = cvara_potva(1, iel)
icodcl(ifac,ipotva + 1) = 1
rcodcl(ifac,ipotva + 1,1) = cvara_potva(2, iel)
icodcl(ifac,ipotva + 2) = 1
rcodcl(ifac,ipotva + 2,1) = cvara_potva(3, iel)
endif
endif
enddo
Example 5
For boundary faces of color 51 assign a wall and restriking model for electric arc (anode boundaray condition).
call getfbr('51', nlelt, lstelt)
do ilelt = 1, nlelt
izone = 5
! ---- Enthalpy (J/kg) :
! imposed heat transfer coefficient
ii=iscalt
rcodcl(ifac,isca(ii),1) = 2.d4
rcodcl(ifac,isca(ii),2) = 1.d5
! Real electrical potential: anode boundary condition;
! pot_diff calculated in cs_user_electric_scaling.c
else
rcodcl(ifac,ipotr,1) = 100.d0
endif
! Restriking modeling:
! example to fit depending on the case, the geometry etc...
! and also in agreement with cs_user_electric_scaling.c
if (irestrike.eq.1 .and. ntcabs.le.ntdcla+30) then
z1 = restrike_point_z - 2.d-4
if (z1.le.0.d0) z1 = 0.d0
z2 = restrike_point_z + 2.d-4
if (z2.ge.2.d-2) z2 = 2.d-2
if (cdgfbo(3,ifac).ge.z1 .and. cdgfbo(3,ifac).le.z2) then
rcodcl(ifac,isca(ii),1) = pot_diff
else
icodcl(ifac,isca(ii)) = 3
rcodcl(ifac,isca(ii),3) = 0.d0
endif
endif
endif
! Vector potential : Zero flux
endif
enddo
Example 6
For boundary faces of color 4 assign a symmetry.
call getfbr('4', nlelt, lstelt)
do ilelt = 1, nlelt
! Symmetries
itypfb(ifac) = isymet
izone = 6
! For all scalars, by default a zero flux condition is assumed
! (for potentials also)
! In Joule effect direct conduction,
! we can use an anti-symetry condition for the imaginary component of the
! electrical potential depending on the electrode configuration:
endif
enddo
