This function is called at the end of each time step, and has a very general purpose (i.e. anything that does not have another dedicated user subroutine)
cs_f_user_extra_operations subroutine
Local variables
integer iscal, ivar, iortho, iprev
integer inc, iccocg, ilelt, irangv
integer ifac, iel, npoint, iel1, irang1, ii, iun, impout, nlelt, neltg
double precision diipbx, diipby, diipbz
double precision xtbulk, xubulk, xyz(3), xtb, xub, tfac,
lambda, xab
character*19 namfil
integer, allocatable, dimension(:) :: lstelt
double precision, dimension(:), pointer :: coefap, coefbp, cofafp
double precision, allocatable, dimension(:,:) :: grad
double precision, allocatable, dimension(:) :: treco,treglo,treloc
double precision, allocatable, dimension(:) :: xnusselt
double precision, allocatable, dimension(:) :: xabs, xabsg
double precision,
dimension(:,:),
pointer ::
vel double precision, dimension(:), pointer :: cvar, viscl
double precision :: height, prandtl, qwall
parameter(height = 1.0d0)
parameter(prandtl = 1.0d0)
parameter(qwall = 1.0d0)
Calculation of the Nusselt number
if (ntcabs.eq.ntmabs) then
allocate(lstelt(max(ncel,nfac,nfabor)))
call field_get_val_v(ivarfl(iu),
vel)
iscal = iscalt
ivar = isca(iscal)
call field_get_val_s(iviscl, viscl)
call field_get_coefa_s(ivarfl(ivar), coefap)
call field_get_coefb_s(ivarfl(ivar), coefbp)
call field_get_val_s(ivarfl(ivar), cvar)
Compute value reconstructed at I' for boundary faces
allocate(treco(nfabor))
iortho = 0
General cas (for non-orthogonal meshes)
Allocate a work array for the gradient calculation
Compute gradient
iprev = 0
inc = 1
iccocg = 1
call field_gradient_scalar(ivarfl(ivar), iprev, imrgra, inc, &
iccocg, &
grad)
Compute reconstructed value in boundary cells
do ifac = 1, nfabor
iel = ifabor(ifac)
diipbx = diipb(1,ifac)
diipby = diipb(2,ifac)
diipbz = diipb(3,ifac)
treco(ifac) = coefap(ifac) + coefbp(ifac)*(cvar(iel) &
+ diipbx*grad(1,iel) &
+ diipby*grad(2,iel) &
+ diipbz*grad(3,iel))
enddo
Free memory
Case of orthogonal meshes
- Note
- Here, we assign the non-reconstructed value.
do ifac = 1, nfabor
iel = ifabor(ifac)
treco(ifac) = coefap(ifac) + coefbp(ifac)*cvar(iel)
enddo
endif
impout = impusr(1)
if (irangp.le.0) then
open(file="Nusselt.dat",unit=impout)
endif
call getfbr(
'normal[0,-1,0,0.1] and y < 0.01',nlelt,lstelt)
neltg = nlelt
if (irangp.ge.0) then
call parcpt(neltg)
endif
allocate(xabs(nlelt))
allocate(treloc(nlelt))
allocate(xnusselt(neltg))
allocate(xabsg(neltg))
allocate(treglo(neltg))
endif
do ilelt = 1, nlelt
ifac = lstelt(ilelt)
xabs(ilelt) = cdgfbo(1,ifac)
treloc(ilelt) = treco(ifac)
enddo
call paragv(nlelt, neltg, xabs, xabsg)
call paragv(nlelt, neltg, treloc, treglo)
endif
do ilelt = 1,neltg
Calculation of the bulk temperature
xab = xabsg(ilelt)
else
xab = xabs(ilelt)
endif
xtbulk = 0.0d0
xubulk = 0.0d0
npoint = 200
iel1 = -999
do ii = 1, npoint
xyz(1) = xab
xyz(2) = float(ii-1)/float(npoint-1)
xyz(3) = 0.d0
call findpt(ncelet, ncel, xyzcen, xyz(1), xyz(2), xyz(3), iel, irangv)
if ((iel.ne.iel1).or.(irangv.ne.irang1)) then
iel1 = iel
irang1 = irangv
if (irangp.eq.irangv) then
xtb = volume(iel)*cvar(iel)*
vel(1,iel)
xub = volume(iel)*
vel(1,iel)
xtbulk = xtbulk + xtb
xubulk = xubulk + xub
lambda = cp0 * viscl(iel) / prandtl
endif
endif
enddo
iun = 1
call parall_bcast_r(irangv,
lambda)
call parsom(xtbulk)
call parsom(xubulk)
endif
xtbulk = xtbulk/xubulk
tfac = treglo(ilelt)
else
tfac = treloc(ilelt)
endif
xnusselt(ilelt) = qwall * 2.d0 * height /
lambda / (tfac - xtbulk)
enddo
if (irangp.eq.-1) then
do ii = 1, neltg
write(impout,'(2E17.9)') xabs(ii)*10, xnusselt(ii)/(0.023d0*30000.d0**(0.8d0)*0.71d0**(0.4d0))
enddo
endif
if (irangp.eq.0) then
call sortc2(xabsg, xnusselt, neltg)
do ii = 1, neltg
write(impout,'(2E17.9)') xabsg(ii)*10, xnusselt(ii)/(0.023d0*30000.d0**(0.8d0)*0.71d0**(0.4d0))
enddo
endif
close(impout)
deallocate(treco)
deallocate(xabs)
deallocate(xnusselt)
deallocate(lstelt)
deallocate(treloc)
deallocate(xabsg)
deallocate(treglo)
endif
endif
return
sortc2 subroutine
Local variables
implicit none
integer n
double precision tab1(n), tab2(n)
integer ns, ii, jj, kk
double precision tabmin, t2
Body
ns = 1
do ii = 1, n-1
tabmin = 1.d20
kk = 0
do jj = ns,n
if (tabmin.gt.tab1(jj)) then
tabmin = tab1(jj)
kk = jj
endif
enddo
t2 = tab2(kk)
tab1(kk) = tab1(ns)
tab2(kk) = tab2(ns)
tab2(ns) = t2
tab1(ns) = tabmin
ns = ns + 1
enddo
return
end subroutine sortc2
