cs_vof.h
1 #ifndef __CS_VOF_H__
2 #define __CS_VOF_H__
5  * Functions associated to VOF model
35  * Local headers
38 #include "cs_base.h"
39 #include "cs_domain.h"
46  * Macro definitions
48
60 #define CS_VOF_ENABLED (1 << 0)
61
63 #define CS_VOF_FREE_SURFACE (1 << 1)
64
66 #define CS_VOF_MERKLE_MASS_TRANSFER (1 << 2)
67
74 /*============================================================================
75  * Type definitions
76  *============================================================================*/
77
78 /* VOF model parameters */
79 /*----------------------*/
80
81 typedef struct {
82
83  unsigned vof_model; /* VoF model (sum of masks defining Volume of
84  Fluid model and submodels */
85
86  double rho1; /* density */
87
88  double rho2;
89
90  double mu1; /* viscosity */
91
92  double mu2;
93
95
96 /* Cavitation parameters */
97 /*-----------------------*/
98
99 typedef struct {
100
101  cs_real_t presat; /* reference saturation pressure */
102  cs_real_t uinf; /* reference velocity */
103  cs_real_t linf; /* reference length scale */
104  cs_real_t cdest; /* constant of condensation model (Merkle) */
105  cs_real_t cprod; /* constant of vaporization model (Merkle) */
106  int icvevm; /* eddy-viscosity correction indicator */
107  cs_real_t mcav; /* eddy-viscosity correction cstt (Reboud) */
108  int itscvi; /* eddy-viscosity correction indicator */
109
111
112 /*=============================================================================
113  * Global variables
114  *============================================================================*/
115
116 /* pointer to VOF model parameters structure */
117
119
120 /*============================================================================
121  * Public function prototypes
122  *============================================================================*/
123
124 /*----------------------------------------------------------------------------
125  *!
126  * \brief Provide access to VOF structure.
127  */
129
132
133 /*----------------------------------------------------------------------------*/
150 /*----------------------------------------------------------------------------*/
151
152 void
154
155 /*----------------------------------------------------------------------------*/
185 /*----------------------------------------------------------------------------*/
186
187 void
188 cs_vof_update_phys_prop(const cs_domain_t *domain);
189
190 /*----------------------------------------------------------------------------*/
200 /*----------------------------------------------------------------------------*/
201
202 void
203 cs_vof_log_mass_budget(const cs_domain_t *domain);
204
205 /*----------------------------------------------------------------------------
206  *!
207  * \brief Provide access to cavitation parameters structure.
208  */
209 /*----------------------------------------------------------------------------*/
210
213
214 /*----------------------------------------------------------------------------*/
215
217
218 #endif /* __CS_VOF_H__ */
cs_real_t mcav
Definition: cs_vof.h:107
void cs_vof_log_mass_budget(const cs_domain_t *domain)
Write in main log the global mixture mass budget: .
Definition: cs_vof.c:525
void cs_vof_compute_linear_rho_mu(const cs_domain_t *domain)
Compute the mixture density, mixture dynamic viscosity given fluid volume fractions and the reference...
Definition: cs_vof.c:391
Definition: cs_defs.h:467
VOF model parameters. Void fraction variable tracks fluid 2.
Definition: cs_vof.h:81
cs_real_t uinf
Definition: cs_vof.h:102
cs_vof_parameters_t * cs_get_glob_vof_parameters(void)
Definition: cs_vof.c:366
Definition: cs_defs.h:302
void cs_vof_update_phys_prop(const cs_domain_t *domain)
Compute the mixture density, mixture dynamic viscosity and mixture mass flux given the volumetric flu...
Definition: cs_vof.c:469
unsigned vof_model
Definition: cs_vof.h:83
double rho1
Definition: cs_vof.h:86
Definition: cs_domain.h:87
cs_real_t cprod
Definition: cs_vof.h:105
cs_real_t cdest
Definition: cs_vof.h:104
cs_real_t linf
Definition: cs_vof.h:103
double rho2
Definition: cs_vof.h:88
Definition: cs_defs.h:468
double mu1
Definition: cs_vof.h:90
const cs_vof_parameters_t * cs_glob_vof_parameters
cs_real_t presat
Definition: cs_vof.h:101
cs_cavitation_parameters_t * cs_get_glob_cavitation_parameters(void)
Definition: cs_vof.c:659
Cavitation model parameters.
Definition: cs_vof.h:99
int itscvi
Definition: cs_vof.h:108
double mu2
Definition: cs_vof.h:92
int icvevm
Definition: cs_vof.h:106
