cs_stokes_model.h
1 #ifndef __CS_STOKES_MODEL_H__
2 #define __CS_STOKES_MODEL_H__
5  * Stokes equation model data.
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
45  * Type definitions
48 /* Stokes equation model descriptor */
49 /*---------------------------*/
50
51 typedef struct {
52
53  int ivisse; /* take viscous term of transposed velocity
54  gradient into account in momentum equation
55  - 1: true (default)
56  - 0: false */
57  int irevmc; /* reconstruction of the velocity field with the
58  updated pressure option
59  - 0: default */
60  int iprco; /* compute the pressure step thanks to the
61  continuity equation
62  - 1: true (default)
63  - 0: false */
64  double arak; /* Arakawa multiplicator for the Rhie and Chow
65  filter (1 by default) */
66  int ipucou; /* pseudo coupled pressure-velocity solver
67  - 1: true (default)
68  - 0: false */
69  int iccvfg; /* calculation with a fixed velocity field
70  - 1: true (default)
71  - 0: false */
72  int idilat; /* algorithm to take into account the density
73  variation in time
74  - 1: dilatable steady algorithm (default)
75  - 2: dilatable unsteady algorithm
76  - 3: low-Mach algorithm
77  - 4: algorithm for fire
78  - 0: boussinesq algorithm with constant
79  density */
80  double epsdp; /* parameter of diagonal pressure strengthening */
81  int itbrrb; /* accurate treatment of the wall temperature
82  - 1: true
83  - 0: false (default) */
84  int iphydr; /* improve hydrostatic pressure algorithm
85  - 1: impose the equilibrium of the hydrostaic
86  part of the pressure with any external force,
87  even head losses
88  - 2: compute an hydrostatic pressure due to
89  buoyancy forces before the prediction step
90  - 0: no treatment (default) */
91  int igprij; /* improve static pressure algorithm
92  - 1: take -div(rho R) in the static pressure
93  treatment IF iphydr=1
94  - 0: no treatment (default) */
95  int igpust; /* improve static pressure algorithm
96  - 1: take user momemtum source terms in the
97  static pressure treatment IF iphydr=1 (default)
98  - 0: no treatment */
99  int iifren; /* indicates the presence of a Bernoulli boundary
100  face (automatically computed)
101  - 0: no face
102  - 1: at least one face */
103  int icalhy; /* compute the hydrostatic pressure in order to
104  compute the Dirichlet conditions on the
105  pressure at outlets
106  - 1: true
107  - 0: false (default) */
108  int irecmf; /* use interpolated face diffusion coefficient
109  instead of cell diffusion coefficient for the
110  mass flux reconstruction for the
111  non-orthogonalities
112  - 1: true
113  - 0: false (default) */
114
116
117 /*============================================================================
118  * Static global variables
119  *============================================================================*/
120
121 /* Pointer to main Stokes model structure */
122
124
125 /*=============================================================================
126  * Public function prototypes
127  *============================================================================*/
128
129 /*----------------------------------------------------------------------------
130  * Provide acces to cs_glob_stokes_model
131  *
132  * needed to initialize structure with GUI
133  *----------------------------------------------------------------------------*/
134
137
138 /*----------------------------------------------------------------------------*/
142 /*----------------------------------------------------------------------------*/
143
144 void
146
147 /*----------------------------------------------------------------------------*/
148
150
151 #endif /* __CS_STOKES_MODEL_H__ */
int itbrrb
Definition: cs_stokes_model.h:81
double arak
Definition: cs_stokes_model.h:64
void cs_stokes_model_log_setup(void)
Print the stokes model parameters to setup.log.
Definition: cs_stokes_model.c:364
int iccvfg
Definition: cs_stokes_model.h:69
int ivisse
Definition: cs_stokes_model.h:53
Definition: cs_defs.h:467
int irecmf
Definition: cs_stokes_model.h:108
int ipucou
Definition: cs_stokes_model.h:66
int irevmc
Definition: cs_stokes_model.h:57
int iifren
Definition: cs_stokes_model.h:99
const cs_stokes_model_t * cs_glob_stokes_model
int igpust
Definition: cs_stokes_model.h:95
int icalhy
Definition: cs_stokes_model.h:103
int idilat
Definition: cs_stokes_model.h:72
int iphydr
Definition: cs_stokes_model.h:84
Definition: cs_defs.h:468
int iprco
Definition: cs_stokes_model.h:60
Stokes equation model descriptor.
Definition: cs_stokes_model.h:51
cs_stokes_model_t * cs_get_glob_stokes_model(void)
Definition: cs_stokes_model.c:352
double epsdp
Definition: cs_stokes_model.h:80
int igprij
Definition: cs_stokes_model.h:91
