cs_sat_coupling.h
1 #ifndef __CS_SAT_COUPLING_H__
2 #define __CS_SAT_COUPLING_H__
5  * Functions associated with code coupling.
35  * Local headers
38 #include "fvm_defs.h"
39 #include "fvm_nodal.h"
41 #include "cs_base.h"
46
48  * Type Definitions
50
51 typedef struct _cs_sat_coupling_t cs_sat_coupling_t;
52
53 /*----------------------------------------------------------------------------
54  * Function pointer to mesh tagging function.
55  *
56  * Each function of this sort may be used to tag a mesh and associated
57  * points for mocatin exclusion.
58  *
59  * Note: if the context pointer is non-NULL, it must point to valid data
60  * when the selection function is called, so that value or structure
61  * should not be temporary (i.e. local);
62  *
63  * parameters:
64  * context <-> pointer to optional (untyped) value or structure.
65  * mesh <-> nodal mesh which should be tagged
66  * n_points <-- number of points to tag
67  * point_list_base <-- base numbering for point_list
68  * point_list <-- optional indirection for points
69  * point_tag --> point tag values (size: n_tags)
70  *----------------------------------------------------------------------------*/
71
72 typedef void
73 (cs_sat_coupling_tag_t) (void *context,
74  fvm_nodal_t *mesh,
75  cs_lnum_t n_points,
76  cs_lnum_t point_list_base,
77  const cs_lnum_t point_list[],
78  int *point_tag);
79
80 /*============================================================================
81  * Public function prototypes for Fortran API
82  *============================================================================*/
83
84 /*----------------------------------------------------------------------------
85  * Get number of code coupling
86  *
87  * Fortran interface:
88  *
89  * SUBROUTINE NBCCPL
90  * *****************
91  *
92  * INTEGER NBRCPL : <-- : number of code couplings
93  *----------------------------------------------------------------------------*/
94
95 void CS_PROCF (nbccpl, NBCCPL)
96 (
98 );
99
100 /*----------------------------------------------------------------------------
101  * Set the list of cells and boundary faces associated to a coupling
102  * and a cloud of point.
103  *
104  * The local "support" cells and boundary faces are used to localize
105  * the values in the distant "coupled" cells and faces.
106  * Depending on the role of sender and/or receiver of the current process
107  * in the coupling, some of these sets can be empty or not.
108  *
109  * The cell values are always localized and interpolated on the distant
110  * "cells" support. The face values are localized and interpolated on
111  * the distant "face" support if present, or on the distant "cell" support
112  * if not.
113  *
114  * If the input arrays LCESUP and LFBSUP are not ordered, they will be
115  * orderd in output.
116  *
117  * Fortran interface:
118  *
119  * SUBROUTINE DEFCPL
120  * *****************
121  *
122  * INTEGER NUMCPL : --> : coupling number
123  *----------------------------------------------------------------------------*/
124
125 void CS_PROCF (defloc, DEFLOC)
126 (
127  const cs_int_t *numcpl
128 );
129
130 /*----------------------------------------------------------------------------
131  * Get the number of cells and boundary faces, "support", coupled and not
132  * localized associated to a given coupling
133  *
134  * Fortran interface:
135  *
136  * SUBROUTINE NBECPL
137  * *****************
138  *
139  * INTEGER NUMCPL : --> : coupling number
140  * INTEGER NCESUP : <-- : number of "support" cells
141  * INTEGER NFBSUP : <-- : number of "support" boundary faces
142  * INTEGER NCECPL : <-- : number of coupled cells
143  * INTEGER NFBCPL : <-- : number of coupled boundary faces
144  * INTEGER NCENCP : <-- : number of not coupled cells
145  * : : (since not localized)
146  * INTEGER NFBNCP : <-- : number of not coupled boundary faces
147  * : : (since not localized)
148  *----------------------------------------------------------------------------*/
149
150 void CS_PROCF (nbecpl, NBECPL)
151 (
152  const cs_int_t *numcpl,
153  cs_int_t *ncesup,
154  cs_int_t *nfbsup,
155  cs_int_t *ncecpl,
156  cs_int_t *nfbcpl,
157  cs_int_t *ncencp,
158  cs_int_t *nfbncp
159 );
160
161 /*----------------------------------------------------------------------------
162  * Get the lists of coupled cells and boundary faces (i.e. receiving)
163  * associated to a given coupling
164  *
165  * The number of cells and boundary faces, got with NBECPL(), are used
166  * for arguments coherency checks.
167  *
168  * Fortran interface:
169  *
170  * SUBROUTINE LELCPL
171  * *****************
172  *
173  * INTEGER NUMCPL : --> : coupling number
174  * INTEGER NCECPL : --> : number of coupled cells
175  * INTEGER NFBCPL : --> : number of coupled boundary faces
176  * INTEGER LCECPL(*) : <-- : list of coupled cells
177  * INTEGER LFBCPL(*) : <-- : list of coupled boundary faces
178  *----------------------------------------------------------------------------*/
179
180 void CS_PROCF (lelcpl, LELCPL)
181 (
182  const cs_int_t *numcpl,
183  const cs_int_t *ncecpl,
184  const cs_int_t *nfbcpl,
185  cs_int_t *lcecpl,
186  cs_int_t *lfbcpl
187 );
188
189 /*----------------------------------------------------------------------------
190  * Get the lists of not coupled cells and boundary faces (i.e. receiving but
191  * not localized) associated to a given coupling
192  *
193  * The number of cells and boundary faces, got with NBECPL(), are used
194  * for arguments coherency checks.
195  *
196  * Fortran interface:
197  *
198  * SUBROUTINE LENCPL
199  * *****************
200  *
201  * INTEGER NUMCPL : --> : coupling number
202  * INTEGER NCENCP : --> : number of not coupled cells
203  * INTEGER NFBNCP : --> : number of not coupled boundary faces
204  * INTEGER LCENCP(*) : <-- : list of not coupled cells
205  * INTEGER LFBNCP(*) : <-- : list of not coupled boundary faces
206  *----------------------------------------------------------------------------*/
207
208 void CS_PROCF (lencpl, LENCPL)
209 (
210  const cs_int_t *numcpl,
211  const cs_int_t *ncencp,
212  const cs_int_t *nfbncp,
213  cs_int_t *lcencp,
214  cs_int_t *lfbncp
215 );
216
217 /*----------------------------------------------------------------------------
218  * Get the number of distant point associated to a given coupling
219  * and localized on the local domain
220  *
221  * Fortran interface:
222  *
223  * SUBROUTINE NPDCPL
224  * *****************
225  *
226  * INTEGER NUMCPL : --> : coupling number
227  * INTEGER NCEDIS : <-- : number of distant cells
228  * INTEGER NFBDIS : <-- : numbre de distant boundary faces
229  *----------------------------------------------------------------------------*/
230
231 void CS_PROCF (npdcpl, NPDCPL)
232 (
233  const cs_int_t *numcpl,
234  cs_int_t *ncedis,
235  cs_int_t *nfbdis
236 );
237
238 /*----------------------------------------------------------------------------
239  * Get the distant points coordinates associated to a given coupling
240  * and a list of points, and the elements number and type (cell or face)
241  * "containing" this points.
242  *
243  * The number of distant points NBRPTS must be equal to one the arguments
244  * NCEDIS or NFBDIS given by NPDCPL(), and is given here for coherency checks
245  * between the arguments NUMCPL and ITYSUP.
246  *
247  * Fortran interface:
248  *
249  * SUBROUTINE COOCPL
250  * *****************
251  *
252  * INTEGER NUMCPL : --> : coupling number
253  * INTEGER NBRPTS : --> : number of distant points
254  * INTEGER ITYDIS : --> : 1 : access to the points associated
255  * : : to the distant cells
256  * : : 2 : access to the points associated
257  * : : to the distant boundary faces
258  * INTEGER ITYLOC : <-- : 1 : localization on the local cells
259  * : : 2 : localization on the local faces
260  * INTEGER LOCPTS(*) : <-- : "containing" number associated to
261  * : : each point
262  * DOUBLE PRECISION COOPTS(3,*) : <-- : distant point coordinates
263  *----------------------------------------------------------------------------*/
264
265 void CS_PROCF (coocpl, COOCPL)
266 (
267  const cs_int_t *numcpl,
268  const cs_int_t *nbrpts,
269  const cs_int_t *itydis,
270  cs_int_t *ityloc,
271  cs_int_t *locpts,
272  cs_real_t *coopts,
273  cs_real_t *djppts,
274  cs_real_t *dofpts,
275  cs_real_t *pndpts
276 );
277
278 /*----------------------------------------------------------------------------
279  * Get the weighting coefficient needed for a centered-like interpolation
280  * in the case of a coupling on boundary faces.
281  *
282  * Fortran interface:
283  *
284  * SUBROUTINE PONDCP
285  * *****************
286  *
287  * INTEGER NUMCPL : --> : coupling number
288  * INTEGER NBRCPL : --> : number of distant points
289  * INTEGER ITYLOC : <-- : 1 : localization on the local cells
290  * : : 2 : localization on the local faces
291  * DOUBLE PRECISION pndcpl(*) : <-- : weighting coefficients
292  *----------------------------------------------------------------------------*/
293
294 void CS_PROCF (pondcp, PONDCP)
295 (
296  const cs_int_t *numcpl,
297  const cs_int_t *nbrcpl,
298  cs_int_t *ityloc,
299  cs_real_t *pndcpl,
300  cs_real_t *distof
301 );
302
303 /*----------------------------------------------------------------------------
304  * Exchange a variable associated to a set of point and a coupling.
305  *
306  * Fortran interface:
307  *
308  * SUBROUTINE VARCPL
309  * *****************
310  *
311  * INTEGER NUMCPL : --> : coupling number
312  * INTEGER NBRDIS : --> : number of values to send
313  * INTEGER NBRLOC : --> : number of values to receive
314  * INTEGER ITYVAR : --> : 1 : variables defined at cells
315  * : : 2 : variables defined at faces
316  * INTEGER STRIDE : --> : 1 : for scalars
317  * : : 3 : for vectors
318  * DOUBLE PRECISION VARDIS(*) : --> : distant variable(to send)
319  * DOUBLE PRECISION VARLOC(*) : <-- : local variable (to receive)
320  *----------------------------------------------------------------------------*/
321
322 void CS_PROCF (varcpl, VARCPL)
323 (
324  const cs_int_t *numcpl,
325  const cs_int_t *nbrdis,
326  const cs_int_t *nbrloc,
327  const cs_int_t *ityvar,
328  const cs_int_t *stride,
329  cs_real_t *vardis,
330  cs_real_t *varloc
331 );
332
333 /*----------------------------------------------------------------------------
334  * Array of integers exchange, associated to a given coupling.
335  *
336  * It is assumed that the arrays have the same size and the same values on
337  * each group of processus (local and distant).
338  *
339  * Fortran interface:
340  *
341  * SUBROUTINE TBICPL
342  * *****************
343  *
344  * INTEGER NUMCPL : --> : coupling number
345  * INTEGER NBRDIS : --> : number of values to send
346  * INTEGER NBRLOC : --> : number of values to receive
347  * INTEGER TABDIS(*) : --> : distant values (to send)
348  * INTEGER TABLOC(*) : <-- : local values (to receive)
349  *----------------------------------------------------------------------------*/
350
351 void CS_PROCF (tbicpl, TBICPL)
352 (
353  const cs_int_t *numcpl,
354  const cs_int_t *nbrdis,
355  const cs_int_t *nbrloc,
356  cs_int_t *vardis,
357  cs_int_t *varloc
358 );
359
360 /*----------------------------------------------------------------------------
361  * Array of reals exchange, associated to a given coupling.
362  *
363  * It is assumed that the arrays have the same size and the same values on
364  * each group of processus (local and distant).
365  *
366  * Fortran interface:
367  *
368  * SUBROUTINE TBRCPL
369  * *****************
370  *
371  * INTEGER NUMCPL : --> : coupling number
372  * INTEGER NBRDIS : --> : number of values to send
373  * INTEGER NBRLOC : --> : number of values to receive
374  * DOUBLE PRECISION TABDIS(*) : --> : distant values (to send)
375  * DOUBLE PRECISION TABLOC(*) : <-- : local values (to receive)
376  *----------------------------------------------------------------------------*/
377
378 void CS_PROCF (tbrcpl, TBRCPL)
379 (
380  const cs_int_t *numcpl,
381  const cs_int_t *nbrdis,
382  const cs_int_t *nbrloc,
383  cs_real_t *vardis,
384  cs_real_t *varloc
385 );
386
387 /*----------------------------------------------------------------------------
388  * Compute the maximum value of an integer variable associated to a coupling.
389  *
390  * It is assumed that the integer value is the same for each group of
391  * processus (local and distant).
392  *
393  * Fortran interface:
394  *
395  * SUBROUTINE MXICPL
396  * *****************
397  *
398  * INTEGER NUMCPL : --> : coupling number
399  * INTEGER VALDIS : --> : distant value (to send)
400  * INTEGER VALMAX : <-- : local maximum (to receive)
401  *----------------------------------------------------------------------------*/
402
403 void CS_PROCF (mxicpl, MXICPL)
404 (
405  const cs_int_t *const numcpl,
406  cs_int_t *const vardis,
407  cs_int_t *const varmax
408 );
409
410 /*============================================================================
411  * Public function prototypes
412  *============================================================================*/
413
414 /*----------------------------------------------------------------------------*/
435 /*----------------------------------------------------------------------------*/
436
437 void
438 cs_sat_coupling_define(const char *saturne_name,
439  const char *boundary_cpl_criteria,
440  const char *volume_cpl_criteria,
441  const char *boundary_loc_criteria,
442  const char *volume_loc_criteria,
443  int verbosity);
444
445 /*----------------------------------------------------------------------------
446  * Get number of Code_Saturne couplings.
447  *
448  * returns:
449  * number of Code_Saturne couplings
450  *----------------------------------------------------------------------------*/
451
452 int
454
455 /*----------------------------------------------------------------------------
456  * Get pointer to Code_Saturne coupling.
457  *
458  * parameters:
459  * coupling_id <-- Id (0 to n-1) of Code_Saturne coupling
460  *
461  * returns:
462  * pointer to Code_Saturne coupling structure
463  *----------------------------------------------------------------------------*/
464
466 cs_sat_coupling_by_id(int coupling_id);
467
468 /*----------------------------------------------------------------------------
469  * Create a sat_coupling_t structure.
470  *
471  * parameters:
472  * ref_axis <-- reference axis
473  * face_sel_criterion <-- criterion for selection of boundary faces
474  * cell_sel_criterion <-- criterion for selection of cells
475  * sat_name <-- Code_Saturne application name
476  * verbosity <-- verbosity level
477  *----------------------------------------------------------------------------*/
478
479 void
480 cs_sat_coupling_add(const char *face_cpl_sel_c,
481  const char *cell_cpl_sel_c,
482  const char *face_loc_sel_c,
483  const char *cell_loc_sel_c,
484  const char *sat_name,
485  int verbosity);
486
487 /*----------------------------------------------------------------------------
488  * Create a new internal Code_Saturne coupling.
489  *
490  * arguments:
491  * tag_func <-- pointer to tagging function
492  * tag_context <-- pointer to tagging function context
493  * boundary_criteria <-- boundary face selection criteria, or NULL
494  * volume_criteria <-- volume cell selection criteria, or NULL
495  * loc_tolerance <-- location tolerance factor (0.1 recommended)
496  * verbosity <-- verbosity level
497  *----------------------------------------------------------------------------*/
498
499 void
501  void *tag_context,
502  const char *boundary_cpl_criteria,
503  const char *volume_cpl_criteria,
504  const char *boundary_loc_criteria,
505  const char *volume_loc_criteria,
506  float loc_tolerance,
507  int verbosity);
508
509 /*----------------------------------------------------------------------------
510  * Initialize Code_Saturne couplings.
511  *
512  * This function may be called once all couplings have been defined,
513  * and it will match defined couplings with available applications.
514  *----------------------------------------------------------------------------*/
515
516 void
518
519 /*----------------------------------------------------------------------------
520  * Destroy all couplings
521  *----------------------------------------------------------------------------*/
522
523 void
525
526 /*----------------------------------------------------------------------------*/
527
529
530 #endif /* __CS_COUPLAGE_H__ */
void nbecpl(const cs_int_t *numcpl, cs_int_t *ncesup, cs_int_t *nfbsup, cs_int_t *ncecpl, cs_int_t *nfbcpl, cs_int_t *ncencp, cs_int_t *nfbncp)
Definition: cs_sat_coupling.c:1142
void varcpl(const cs_int_t *numcpl, const cs_int_t *nbrdis, const cs_int_t *nbrloc, const cs_int_t *ityvar, const cs_int_t *stride, cs_real_t *vardis, cs_real_t *varloc)
Definition: cs_sat_coupling.c:1590
void nbccpl(cs_int_t *nbrcpl)
Definition: cs_sat_coupling.c:840
Definition: cs_defs.h:467
int cs_int_t
Fortran-compatible integer.
Definition: cs_defs.h:301
void defloc(const cs_int_t *numcpl)
Definition: cs_sat_coupling.c:879
void tbrcpl(const cs_int_t *numcpl, const cs_int_t *nbrdis, const cs_int_t *nbrloc, cs_real_t *vardis, cs_real_t *varloc)
Definition: cs_sat_coupling.c:1755
void coocpl(const cs_int_t *numcpl, const cs_int_t *nbrpts, const cs_int_t *itydis, cs_int_t *ityloc, cs_int_t *locpts, cs_real_t *coopts, cs_real_t *djppts, cs_real_t *dofpts, cs_real_t *pndpts)
Definition: cs_sat_coupling.c:1409
Definition: cs_defs.h:302
cs_sat_coupling_t * cs_sat_coupling_by_id(int coupling_id)
Definition: cs_sat_coupling.c:1973
void lencpl(const cs_int_t *numcpl, const cs_int_t *ncencp, const cs_int_t *nfbncp, cs_int_t *lcencp, cs_int_t *lfbncp)
Definition: cs_sat_coupling.c:1279
integer, save nbrcpl
number of couplings Code_Saturne / Code_Saturne
Definition: cplsat.f90:43
void npdcpl(const cs_int_t *numcpl, cs_int_t *ncedis, cs_int_t *nfbdis)
Definition: cs_sat_coupling.c:1349
void tbicpl(const cs_int_t *numcpl, const cs_int_t *nbrdis, const cs_int_t *nbrloc, cs_int_t *vardis, cs_int_t *varloc)
Definition: cs_sat_coupling.c:1679
void cs_sat_coupling_define(const char *saturne_name, const char *boundary_cpl_criteria, const char *volume_cpl_criteria, const char *boundary_loc_criteria, const char *volume_loc_criteria, int verbosity)
Define new Code_Saturne coupling.
Definition: cs_sat_coupling.c:1895
void cs_sat_coupling_add(const char *face_cpl_sel_c, const char *cell_cpl_sel_c, const char *face_loc_sel_c, const char *cell_loc_sel_c, const char *sat_name, int verbosity)
Definition: cs_sat_coupling.c:2030
void cs_sat_coupling_add_internal(cs_sat_coupling_tag_t *tag_func, void *tag_context, const char *boundary_cpl_criteria, const char *volume_cpl_criteria, const char *boundary_loc_criteria, const char *volume_loc_criteria, float loc_tolerance, int verbosity)
Definition: cs_sat_coupling.c:2128
Definition: cs_defs.h:298
void cs_sat_coupling_all_init(void)
Definition: cs_sat_coupling.c:1992
void lelcpl(const cs_int_t *numcpl, const cs_int_t *ncecpl, const cs_int_t *nfbcpl, cs_int_t *lcecpl, cs_int_t *lfbcpl)
Definition: cs_sat_coupling.c:1204
Definition: cs_defs.h:468
#define CS_PROCF(x, y)
Definition: cs_defs.h:481
void pondcp(const cs_int_t *numcpl, const cs_int_t *nbrcpl, cs_int_t *ityloc, cs_real_t *pndcpl, cs_real_t *distof)
Definition: cs_sat_coupling.c:1511
void mxicpl(const cs_int_t *const numcpl, cs_int_t *const vardis, cs_int_t *const varmax)
Definition: cs_sat_coupling.c:1829
void() cs_sat_coupling_tag_t(void *context, fvm_nodal_t *mesh, cs_lnum_t n_points, cs_lnum_t point_list_base, const cs_lnum_t point_list[], int *point_tag)
Definition: cs_sat_coupling.h:73
void cs_sat_coupling_all_finalize(void)
Definition: cs_sat_coupling.c:2166
Definition: mesh.f90:26
Definition: cs_sat_coupling.h:51
int cs_sat_coupling_n_couplings(void)
Definition: cs_sat_coupling.c:1957
