cs_restart_default.h
1 #ifndef __CS_RESTART_DEFAULT_H__
2 #define __CS_RESTART_DEFAULT_H__
5  * Checkpoint/restart handling for default application.
31  * Local headers
34 #include "cs_defs.h"
35 #include "cs_field.h"
36 #include "cs_map.h"
37 #include "cs_restart.h"
38
44  * Macro definitions
46
48  * Type definitions
50
52 /*-------------------*/
53
54 typedef enum {
55
70
71 /*=============================================================================
72  * Public function prototypes
73  *============================================================================*/
74
75 /*----------------------------------------------------------------------------
76  * Read field metadata from checkpoint.
77  *
78  * Old ids associated to each field are determined for future use.
79  * Note that when reading legacy files (Code_Saturne version 3.3 and below),
80  * the old id will actually be the old scalar id (-1 for others).
81  *
82  * parameters:
83  * r <-> associated restart file pointer
84  * old_field_map --> name to id map of fields in restart file
85  *----------------------------------------------------------------------------*/
86
87 void
89  cs_map_name_to_id_t **old_field_map);
90
91 /*----------------------------------------------------------------------------
92  * Write field metadata to checkpoint.
93  *
94  * parameters:
95  * r <-> associated restart file pointer
96  *----------------------------------------------------------------------------*/
97
98 void
100
101 /*----------------------------------------------------------------------------
102  * Read variables from checkpoint.
103  *
104  * parameters:
105  * r <-> associated restart file pointer
106  * old_field_map <-- name to id map of fields in restart file
107  * t_id_flag <-- -1: all time values; 0: current values;
108  * > 0: previous values
109  * read_flag <-- optional flag to track fields read, or NULL;
110  * set to sum of 2^time_id for fields read (size: n_fields)
111  *----------------------------------------------------------------------------*/
112
113 void
115  const cs_map_name_to_id_t *old_field_map,
116  int t_id_flag,
117  int read_flag[]);
118
119 /*----------------------------------------------------------------------------
120  * Write variables to checkpoint.
121  *
122  * parameters:
123  * r <-> associated restart file pointer
124  * t_id_flag <-- -1: all time values; 0: current values;
125  * > 0: previous values
126  * write_flag <-- optional flag to track fields written, or NULL;
127  * set to sum of 2^time_id for fields written (size: n_fields)
128 *----------------------------------------------------------------------------*/
129
130 void
132  int t_id_flag,
133  int write_flag[]);
134
135 /*----------------------------------------------------------------------------
136  * Read fields depending on others from checkpoint.
137  *
138  * Old ids associate to each field are determined for future use.
139  * Note that when reading legacy files (Code_Saturne version 3.3 and below),
140  * the old id will actually be the old scalar id (-1 for others).
141  *
142  * parameters:
143  * r <-> associated restart file pointer
144  * old_field_map <-- name to id map of fields in restart file
145  * key <-- key for field association
146  * read_flag <-- optional flag to track fields read, or NULL;
147  * set to sum of 2^time_id for fields read, -1 for fields
148  * failed to read (size: n_fields)
149  *----------------------------------------------------------------------------*/
150
151 void
153  const cs_map_name_to_id_t *old_field_map,
154  const char *key,
155  int read_flag[]);
156
157 /*----------------------------------------------------------------------------
158  * Write fields depending on others to checkpoint.
159  *
160  * Write field metadata to main checkpoint.
161  *
162  * parameters:
163  * r <-> associated restart file pointer
164  * key <-- key for field association
165  * write_flag <-- optional flag to track fields written, or NULL;
166  * set to sum of 2^time_id for fields written (size: n_fields)
167  *
168  * returns:
169  * number of fields written
170  *----------------------------------------------------------------------------*/
171
172 int
174  const char *key,
175  int write_flag[]);
176
177 /*----------------------------------------------------------------------------
178  * Read boundary condition coefficients for all fields from checkpoint.
179  *
180  * parameters:
181  * r <-> associated restart file pointer
182  *----------------------------------------------------------------------------*/
183
184 void
186
187 /*----------------------------------------------------------------------------
188  * Write boundary condition coefficients for all fields to checkpoint.
189  *
190  * parameters:
191  * r <-> associated restart file pointer
192  *----------------------------------------------------------------------------*/
193
194 void
196
197 /*----------------------------------------------------------------------------
198  * Read field values from checkpoint.
199  *
200  * If the values are not found using the default rules based on the
201  * field's name, its name itself, or a "restart_rename" keyed string value,
202  * an old name may be used for compatibility with older files.
203  * For cell-based fields, the old name base is appended automatically with
204  * "_ce_phase01", except for scalars, where the name uses a different scheme,
205  * based on "scalaire_ce_%04" % s_num;
206  *
207  * parameters:
208  * r <-> associated restart file pointer
209  * f_id <-- field id
210  * t_id <-- time id (0 for current, 1 for previous, ...)
211  *
212  * returns:
213  * CS_RESTART_SUCCESS in case of success, CS_RESTART_ERR_... otherwise
214  *----------------------------------------------------------------------------*/
215
216 int
218  int f_id,
219  int t_id);
220
221 /*----------------------------------------------------------------------------
222  * Write field values to checkpoint.
223  *
224  * parameters:
225  * r <-> associated restart file pointer
226  * f_id <-- field id
227  * t_id <-- time id (0 for current, 1 for previous, ...)
228  *----------------------------------------------------------------------------*/
229
230 void
232  int f_id,
233  int t_id);
234
235 /*----------------------------------------------------------------------------
236  * Read restart time step info.
237  *
238  * parameters:
239  * r <-> associated restart file pointer
240  *----------------------------------------------------------------------------*/
241
242 void
244
245 /*----------------------------------------------------------------------------
246  * Loop over all fields and save them in the restart file which id is
247  * passed in argument if it matches their "restart_file" key value.
248  *
249  * parameters:
250  * r <-> associated restart file pointer
251  * r_id <-- value of the key "restart_file"
252  *----------------------------------------------------------------------------*/
253
254 void
256  cs_restart_file_t r_id);
257
258 /*----------------------------------------------------------------------------
259  * Loop over all fields and read them in the restart file which id is
260  * passed in argument if it matches their "restart_file" key value.
261  *
262  * parameters:
263  * r <-> associated restart file pointer
264  * r_id <-- value of the key "restart_file"
265  *----------------------------------------------------------------------------*/
266
267 void
269  cs_restart_file_t r_id);
270
271 /*----------------------------------------------------------------------------*/
272
274
275 #endif /* __CS_RESTART_DEFAULT_H__ */
Definition: cs_restart_default.h:57
Definition: cs_restart_default.h:59
Definition: cs_defs.h:467
Definition: cs_restart_default.h:58
void cs_restart_write_variables(cs_restart_t *r, int t_id_flag, int write_flag[])
Definition: cs_restart_default.c:1951
void cs_restart_write_field_info(cs_restart_t *r)
Definition: cs_restart_default.c:1711
Definition: cs_restart_default.h:66
struct _cs_map_name_to_id_t cs_map_name_to_id_t
Definition: cs_map.h:48
Definition: cs_restart_default.h:64
void cs_restart_read_time_step_info(cs_restart_t *r)
Definition: cs_restart_default.c:2746
Definition: cs_restart.h:87
void cs_restart_read_variables(cs_restart_t *r, const cs_map_name_to_id_t *old_field_map, int t_id_flag, int read_flag[])
Definition: cs_restart_default.c:1793
int cs_restart_write_linked_fields(cs_restart_t *r, const char *key, int write_flag[])
Definition: cs_restart_default.c:2261
void cs_restart_write_bc_coeffs(cs_restart_t *r)
Definition: cs_restart_default.c:2511
Definition: cs_restart_default.h:61
void cs_restart_read_bc_coeffs(cs_restart_t *r)
Definition: cs_restart_default.c:2355
Definition: cs_defs.h:468
void cs_restart_read_linked_fields(cs_restart_t *r, const cs_map_name_to_id_t *old_field_map, const char *key, int read_flag[])
Definition: cs_restart_default.c:2087
void cs_restart_read_fields(cs_restart_t *r, cs_restart_file_t r_id)
Loop over all fields and read them in the restart file which id is passed in argument if it matches t...
Definition: cs_restart_default.c:2826
void cs_restart_read_field_info(cs_restart_t *r, cs_map_name_to_id_t **old_field_map)
Definition: cs_restart_default.c:1571
Definition: cs_restart_default.h:56
Definition: cs_restart_default.h:62
Definition: cs_restart_default.h:67
cs_restart_file_t
Definition: cs_restart_default.h:54
void cs_restart_write_fields(cs_restart_t *r, cs_restart_file_t r_id)
Loop over all fields and save them in the restart file which id is passed in argument if it matches t...
Definition: cs_restart_default.c:2801
int cs_restart_read_field_vals(cs_restart_t *r, int f_id, int t_id)
Definition: cs_restart_default.c:2625
void cs_restart_write_field_vals(cs_restart_t *r, int f_id, int t_id)
Definition: cs_restart_default.c:2720
