1 #ifndef __CS_RESOURCE_H__ 2 #define __CS_RESOURCE_H__ 30 #if defined(HAVE_CONFIG_H) 31 #include "cs_config.h"
integer(c_int), pointer, save ntmabs
Maximum absolute time step number.
Definition: optcal.f90:375
Definition: cs_defs.h:467
int cs_int_t
Fortran-compatible integer.
Definition: cs_defs.h:301
double cs_resource_get_wt_limit(void)
Get current wall-clock time limit.
Definition: cs_resource.c:250
void cs_resource_get_max_timestep(int ts_cur, int *ts_max)
Limit number of remaining time steps if the remaining allocated time is too small to attain the reque...
Definition: cs_resource.c:280
void cs_resource_set_wt_limit(double wt)
Set wall-clock time limit.
Definition: cs_resource.c:264
Definition: cs_defs.h:468
void armtps(const cs_int_t *ntcabs, cs_int_t *ntmabs)
Definition: cs_resource.c:225
integer(c_int), pointer, save ntcabs
Current absolute time step number. In case of restart, this is equal to ntpabs + number of new iterat...
Definition: optcal.f90:366
#define CS_PROCF(x, y)
Definition: cs_defs.h:481
