cs_renumber.h
1 #ifndef __CS_RENUMBER_H__
2 #define __CS_RENUMBER_H__
5  * Optional mesh renumbering
31  * Local headers
34 #include "cs_base.h"
35 #include "cs_mesh.h"
36
38
42  * Macro definitions
46  * Type definitions
48
49 /* Renumbering algorithms */
50
51 typedef enum {
52
53  CS_RENUMBER_CELLS_SCOTCH_PART, /* SCOTCH partitioning */
54  CS_RENUMBER_CELLS_SCOTCH_ORDER, /* SCOTCH ordering */
55  CS_RENUMBER_CELLS_METIS_PART, /* METIS partitioning */
56  CS_RENUMBER_CELLS_METIS_ORDER, /* METIS ordering */
57  CS_RENUMBER_CELLS_MORTON, /* Morton space filling curve */
58  CS_RENUMBER_CELLS_HILBERT, /* Hilbert space filling curve */
59  CS_RENUMBER_CELLS_RCM, /* Reverse Cuthill-McKee */
60  CS_RENUMBER_CELLS_NONE /* No cells renumbering */
61
63
64 typedef enum {
65
66  CS_RENUMBER_I_FACES_BLOCK, /* No shared cell in block */
67  CS_RENUMBER_I_FACES_MULTIPASS, /* Use multipass face numbering */
68  CS_RENUMBER_I_FACES_SIMD, /* Renumber for vector (SIMD) operations */
69  CS_RENUMBER_I_FACES_NONE /* No interior face numbering */
70
72
73 typedef enum {
74
75  CS_RENUMBER_B_FACES_THREAD, /* No cell shared between threads */
76  CS_RENUMBER_B_FACES_SIMD, /* Renumber for vector (SIMD) operations */
77  CS_RENUMBER_B_FACES_NONE /* No boundary face numbering */
78
80
81 typedef enum {
82
83  CS_RENUMBER_VERTICES_BY_CELL_ADJ, /* Renumbering based on cell adjacency */
84  CS_RENUMBER_VERTICES_BY_FACE_ADJ, /* Renumbering based on face adjacency */
85  CS_RENUMBER_VERTICES_NONE /* No vertex numbering */
86
88
89 /* Ordering options for adjacency arrays */
90
91 typedef enum {
92
93  CS_RENUMBER_ADJACENT_LOW, /* Lowest adjacent id first */
94  CS_RENUMBER_ADJACENT_HIGH /* Highest adjacent id first */
95
97
98 /*=============================================================================
99  * Public function prototypes
100  *============================================================================*/
101
102 /*----------------------------------------------------------------------------
103  * Set the target number of threads for mesh renumbering.
104  *
105  * By default, the target number of threads is set to cs_glob_n_threads,
106  * but the value may be forced using this function. This is mainly useful
107  * for testing purposes.
108  *
109  * parameters:
110  * n_threads <-- target number of threads for mesh numbering
111  *----------------------------------------------------------------------------*/
112
113 void
114 cs_renumber_set_n_threads(int n_threads);
115
116 /*----------------------------------------------------------------------------
117  * Return the target number of threads for mesh renumbering.
118  *
119  * returns:
120  * the target number of threads for mesh numbering
121  *----------------------------------------------------------------------------*/
122
123 int
125
126 /*----------------------------------------------------------------------------
127  * Set the minimum sunset sizes when renumbering for threads.
128  *
129  * parameters:
130  * min_i_subset_size <-- minimum number of interior faces per
131  * thread per group
132  * min_b_subset_size <-- minimum number of boundary faces per
133  * thread per group
134  *----------------------------------------------------------------------------*/
135
136 void
138  cs_lnum_t min_b_subset_size);
139
140 /*----------------------------------------------------------------------------
141  * Get the minimum sunset sizes when renumbering for threads.
142  *
143  * min_i_subset_size --> minimum number of interior faces per
144  * thread per group, or NULL
145  * min_b_subset_size --> minimum number of boundary faces per
146  * thread per group, or NULL
147  *----------------------------------------------------------------------------*/
148
149 void
150 cs_renumber_get_min_subset_size(cs_lnum_t *min_i_subset_size,
151  cs_lnum_t *min_b_subset_size);
152
153 /*----------------------------------------------------------------------------*/
171 /*----------------------------------------------------------------------------*/
172
173 void
174 cs_renumber_set_algorithm(bool halo_adjacent_cells_last,
175  bool halo_adjacent_faces_last,
176  cs_renumber_ordering_t i_faces_base_ordering,
177  cs_renumber_cells_type_t cells_pre_numbering,
178  cs_renumber_cells_type_t cells_numbering,
179  cs_renumber_i_faces_type_t i_faces_numbering,
180  cs_renumber_b_faces_type_t b_faces_numbering,
181  cs_renumber_vertices_type_t vertices_numbering);
182
183 /*----------------------------------------------------------------------------*/
203 /*----------------------------------------------------------------------------*/
204
205 void
206 cs_renumber_get_algorithm(bool *halo_adjacent_cells_last,
207  bool *halo_adjacent_faces_last,
208  cs_renumber_ordering_t *i_faces_base_ordering,
209  cs_renumber_cells_type_t *cells_pre_numbering,
210  cs_renumber_cells_type_t *cells_numbering,
211  cs_renumber_i_faces_type_t *i_faces_numbering,
212  cs_renumber_b_faces_type_t *b_faces_numbering,
213  cs_renumber_vertices_type_t *vertices_numbering);
214
215 /*----------------------------------------------------------------------------
216  * Renumber mesh elements for vectorization or threading depending on code
217  * options and target machine.
218  *
219  * Renumbering cells may also allow improving locality (and favor faces
220  * renumbering).
221  * It is also possible to place cells connected to ghost cells last,
222  * which may be useful to enable computation/communication overlap.
223  *
224  * parameters:
225  * mesh <-> pointer to global mesh structure
226  *----------------------------------------------------------------------------*/
227
228 void
230
231 /*----------------------------------------------------------------------------*/
240 /*----------------------------------------------------------------------------*/
241
242 void
244
245 /*----------------------------------------------------------------------------
246  * Renumber interior faces for vectorization or threading depending on code
247  * options and target machine.
248  *
249  * parameters:
250  * mesh <-> pointer to global mesh structure
251  *----------------------------------------------------------------------------*/
252
253 void
255
256 /*----------------------------------------------------------------------------
257  * Renumber interior faces by global number.
258  *
259  * This effectively resets the interior faces to their initial numbering.
260  *
261  * parameters:
262  * mesh <-> pointer to global mesh structure
263  *----------------------------------------------------------------------------*/
264
265 void
267
268 /*----------------------------------------------------------------------------
269  * Renumber boundary faces for vectorization or threading depending on code
270  * options and target machine.
271  *
272  * parameters:
273  * mesh <-> pointer to global mesh structure
274  *----------------------------------------------------------------------------*/
275
276 void
278
279 /*----------------------------------------------------------------------------
280  * Renumber boundary faces by global number.
281  *
282  * This effectively resets the boundary faces to their initial numbering.
283  *
284  * parameters:
285  * mesh <-> pointer to global mesh structure
286  *----------------------------------------------------------------------------*/
287
288 void
290
291 /*----------------------------------------------------------------------------*/
300 /*----------------------------------------------------------------------------*/
301
302 void
304
305 /*----------------------------------------------------------------------------*/
306
308
309 #endif /* __CS_RENUMBER_H__ */
Definition: cs_renumber.h:94
void cs_renumber_i_faces_by_gnum(cs_mesh_t *mesh)
Definition: cs_renumber.c:5984
Definition: cs_renumber.h:53
int cs_renumber_get_n_threads(void)
Definition: cs_renumber.c:5695
void cs_renumber_get_algorithm(bool *halo_adjacent_cells_last, bool *halo_adjacent_faces_last, cs_renumber_ordering_t *i_faces_base_ordering, cs_renumber_cells_type_t *cells_pre_numbering, cs_renumber_cells_type_t *cells_numbering, cs_renumber_i_faces_type_t *i_faces_numbering, cs_renumber_b_faces_type_t *b_faces_numbering, cs_renumber_vertices_type_t *vertices_numbering)
Return the algorithms for mesh renumbering.
Definition: cs_renumber.c:5807
Definition: cs_renumber.h:60
Definition: cs_renumber.h:69
Boundary faces renumbering algorithm types.
Definition: cs_renumber.h:73
Definition: cs_renumber.h:93
Definition: cs_renumber.h:58
Cell renumbering algorithm types.
Definition: cs_renumber.h:51
Definition: cs_renumber.h:77
Definition: cs_renumber.h:83
Definition: cs_defs.h:467
Definition: cs_renumber.h:76
void cs_renumber_set_n_threads(int n_threads)
Definition: cs_renumber.c:5674
Interior faces renumbering algorithm types.
Definition: cs_renumber.h:64
Definition: cs_renumber.h:85
Definition: cs_renumber.h:67
void cs_renumber_b_faces(cs_mesh_t *mesh)
Renumber boundary faces for vectorization or threading depending on code options and target machine...
Definition: cs_renumber.c:6020
Definition: cs_mesh.h:63
void cs_renumber_set_algorithm(bool halo_adjacent_cells_last, bool halo_adjacent_faces_last, cs_renumber_ordering_t i_faces_base_ordering, cs_renumber_cells_type_t cells_pre_numbering, cs_renumber_cells_type_t cells_numbering, cs_renumber_i_faces_type_t i_faces_numbering, cs_renumber_b_faces_type_t b_faces_numbering, cs_renumber_vertices_type_t vertices_numbering)
Select the algorithm for mesh renumbering.
Definition: cs_renumber.c:5764
Definition: cs_renumber.h:59
Definition: cs_renumber.h:56
Definition: cs_renumber.h:55
Definition: cs_renumber.h:75
void cs_renumber_get_min_subset_size(cs_lnum_t *min_i_subset_size, cs_lnum_t *min_b_subset_size)
Definition: cs_renumber.c:5734
Definition: cs_renumber.h:57
void cs_renumber_b_faces_by_gnum(cs_mesh_t *mesh)
Definition: cs_renumber.c:6066
void cs_renumber_cells(cs_mesh_t *mesh)
Renumber cells depending on code options and target machine.
Definition: cs_renumber.c:5888
Definition: cs_renumber.h:66
void cs_renumber_i_faces(cs_mesh_t *mesh)
Renumber interior faces for vectorization or threading depending on code options and target machine...
Definition: cs_renumber.c:5938
Definition: cs_defs.h:298
void cs_renumber_vertices(cs_mesh_t *mesh)
Renumber vertices depending on code options and target machine.
Definition: cs_renumber.c:6102
Definition: cs_defs.h:468
Definition: cs_renumber.h:68
void cs_renumber_set_min_subset_size(cs_lnum_t min_i_subset_size, cs_lnum_t min_b_subset_size)
Definition: cs_renumber.c:5715
Definition: cs_renumber.h:54
Ordering options for adjacency arrays.
Definition: cs_renumber.h:91
void cs_renumber_mesh(cs_mesh_t *mesh)
Renumber mesh elements for vectorization or threading depending on code options and target machine...
Definition: cs_renumber.c:5853
Definition: cs_renumber.h:84
Vertices renumbering algorithm types.
Definition: cs_renumber.h:81
Definition: mesh.f90:26
