cs_partition.h
1 #ifndef __CS_PARTITION_H__
2 #define __CS_PARTITION_H__
5  * Define cs_mesh_t fields from cs_mesh_builder_t fields.
31  * Local headers
34 #include "cs_defs.h"
36 #include "cs_base.h"
38 #include "cs_mesh.h"
39 #include "cs_mesh_builder.h"
46  * Macro definitions
48
50  * Type definitions
52
53 /* Partitioning stage
54  *
55  * Partitioning is always done just after reading the mesh, unless a
56  * partitioning input file is available, in which case the partitioning
57  * read replaces this stage.
58  *
59  * When a mesh modification implying a change of cell connectivity graph
60  * is expected, the mesh may be re-partitioned after the pre-processing
61  * stage, prior to calculation. By default, re-partitioning is only done
62  * if the partitioning algorithm chosen for that stage is expected to
63  * produce different results due to the connectivity change. This is
64  * the case for graph-based algorithms such as those of METIS or SCOTCH,
65  * when mesh joining is defined, or additional periodic matching is defined
66  * (and the algorithm is not configured to ignore periodicity information).
67  *
68  * There are thus two possible partitioning stages:
69  *
70  * - CS_PARTITION_FOR_PREPROCESS, which is optional, and occurs
71  * just after reading the mesh.
72  * - CS_PARTITION_MAIN, which occurs just after reading the mesh if
73  * it is the only stage,, or after mesh preprocessing (and before
74  * computation), if the partitioning for preprocessing stage is
75  * activated.
76  *
77  * The number of partitioning stages is determined automatically based on
78  * information provided through cs_partition_set_preprocess_hints(),
79  * but re-partitioning may also be forced or inhibited using the
80  * cs_partition_set_preprocess() function.
81  */
82
83 typedef enum {
84
85  CS_PARTITION_FOR_PREPROCESS, /* Partitioning for preprocessing stage */
86  CS_PARTITION_MAIN /* Partitioning for computation stage */
87
89
90
91 /* Partitioning algorithm type
92  *
93  * If the default algorithm is selected, the choice will be based on the
94  * following priority, depending on available libraries:
95  * - Pt-Scotch (or Scotch if partitioning on one rank);
96  * - ParMETIS (or METIS if partitioning on one rank);
97  * - Morton space-filling curve (in bounding box)
98  *
99  * If both partitioning stages are active, the default for the preprocessing
100  * stage will be based on the Morton space-filling curve (in bounding box),
101  * as this should be cheaper, and the initial cell connectivity graph
102  * is usually expected to be modified during preprocessing.
103  */
104
105 typedef enum {
106
107  CS_PARTITION_DEFAULT, /* Default partitioning (based on stage) */
108  CS_PARTITION_SFC_MORTON_BOX, /* Morton (Z) curve in bounding box */
109  CS_PARTITION_SFC_MORTON_CUBE, /* Morton (Z) curve in bounding cube */
110  CS_PARTITION_SFC_HILBERT_BOX, /* Peano-Hilbert curve in bounding box */
111  CS_PARTITION_SFC_HILBERT_CUBE, /* Peano-Hilbert curve in bounding cube */
112  CS_PARTITION_SCOTCH, /* PT-SCOTCH or SCOTCH */
113  CS_PARTITION_METIS, /* ParMETIS or METIS */
114  CS_PARTITION_BLOCK /* Unoptimized (naive) block partitioning */
115
117
118 /*============================================================================
119  * Static global variables
120  *============================================================================*/
121
122 /*=============================================================================
123  * Public function prototypes
124  *============================================================================*/
125
126 /*----------------------------------------------------------------------------
127  * Print information on external libraries
128  *----------------------------------------------------------------------------*/
129
130 void
132
133 /*----------------------------------------------------------------------------
134  * Set algorithm for domain partitioning for a given partitioning stage.
135  *
136  * parameters:
137  * stage <-- associated partitioning stage
138  * algorithm <-- partitioning algorithm choice
139  * rank_step <-- if > 1, partitioning done on at most
140  * n_ranks / rank_step processes
141  * (for graph-based partitioning only)
142  * ignore_perio <-- if true, ignore periodicity information when present
143  * when present (for graph-based
144  * (for graph-based partitioning only)
145  *----------------------------------------------------------------------------*/
146
147 void
149  cs_partition_algorithm_t algorithm,
150  int rank_step,
151  bool ignore_perio);
152
153 /*----------------------------------------------------------------------------
154  * Set partitioning write to file option.
155  *
156  * Partitioning information for subsequent calculations is written to file
157  * after the last partitioning stage depending on the output level.
158  *
159  * Note that partitioning information for additional partitionings is
160  * always written to file, regardless of this option.
161  *
162  * parameters:
163  * write_flag <-- option to save partitioning information:
164  * 0: never
165  * 1: for graph-based partitioning only (default)
166  * 2: always
167  *----------------------------------------------------------------------------*/
168
169 void
170 cs_partition_set_write_level(int write_flag);
171
172 /*----------------------------------------------------------------------------
173  * Define hints indicating if initial partitioning fo a preprocessing
174  * stage is required.
175  *
176  * parameters:
177  * join <-- true if a mesh joining operation is planned
178  * join_periodic <-- true if a mesh periodic matching operation is planned
179  *----------------------------------------------------------------------------*/
180
181 void
183  bool join_periodic);
184
185 /*----------------------------------------------------------------------------
186  * Activate or deactivate initial partitioning for preprocessing.
187  *
188  * parameters:
189  * active <-- true to activate pre-partitiong for the preprocessing
190  * stage, false to de-activate it
191  *----------------------------------------------------------------------------*/
192
193 void
194 cs_partition_set_preprocess(bool active);
195
196 /*----------------------------------------------------------------------------
197  * Indicate if initial partitioning for preprocessing is required.
198  *
199  * returns:
200  * true if initial partitioning for preprocessing is active,
201  * false otherwise
202  *----------------------------------------------------------------------------*/
203
204 bool
206
207 /*----------------------------------------------------------------------------
208  * Define list of extra partitionings to build.
209  *
210  * Partitionings in this list will be output to file, and may be used for
211  * subsequent calculations.
212  *
213  * When partitioning for both preprocessing and calculation stages, output to
214  * file of partioning data or generation of additional partitionings
215  * (see \ref cs_partition_add_partitions) will only be done for the
216  * second stage.
217  *
218  * parameters:
219  * n_extra_partitions <-- number of extra partitionings to compute
220  * extra_partitions_list <-- list of extra partitions to compute
221  *----------------------------------------------------------------------------*/
222
223 void
224 cs_partition_add_partitions(int n_extra_partitions,
225  int extra_partitions_list[]);
226
227 /*----------------------------------------------------------------------------
228  * Compute partitioning for a given mesh.
229  *
230  * parameters:
231  * mesh <-- pointer to mesh structure
232  * mesh_builder <-> pointer to mesh builder structure
233  * stage <-- associated partitioning stage
234  *----------------------------------------------------------------------------*/
235
236 void
238  cs_mesh_builder_t *mesh_builder,
239  cs_partition_stage_t stage);
240
241 /*----------------------------------------------------------------------------*/
242
244
245 #endif /* __CS_PARTITION_H__ */
void cs_partition_set_algorithm(cs_partition_stage_t stage, cs_partition_algorithm_t algorithm, int rank_step, bool ignore_perio)
Set algorithm for domain partitioning.
Definition: cs_partition.c:2861
Definition: cs_partition.h:114
Definition: cs_mesh_builder.h:57
Definition: cs_partition.h:86
void cs_partition_add_partitions(int n_extra_partitions, int extra_partitions_list[])
Definition: cs_partition.c:3033
void cs_partition_external_library_info(void)
Print information on external libraries.
Definition: cs_partition.c:2790
Definition: cs_partition.h:108
Definition: cs_partition.h:105
Definition: cs_defs.h:467
void cs_partition(cs_mesh_t *mesh, cs_mesh_builder_t *mesh_builder, cs_partition_stage_t stage)
Partition mesh based on current options.
Definition: cs_partition.c:3057
Definition: cs_partition.h:107
Definition: cs_partition.h:85
Definition: cs_partition.h:112
Definition: cs_mesh.h:63
bool cs_partition_get_preprocess(void)
Indicate if re-partitiong for the computation stage is required.
Definition: cs_partition.c:2988
Definition: cs_partition.h:109
Definition: cs_partition.h:113
void cs_partition_set_write_level(int write_flag)
Definition: cs_partition.c:2936
Definition: cs_partition.h:83
Definition: cs_partition.h:111
void cs_partition_set_preprocess_hints(bool join, bool join_periodic)
Define hints indicating if initial partitioning fo a preprocessing stage is required.
Definition: cs_partition.c:2953
Definition: cs_defs.h:468
void cs_partition_set_preprocess(bool active)
Definition: cs_partition.c:2970
Definition: cs_partition.h:110
Definition: mesh.f90:26
