cs_paramedmem_remapper.hxx
1 #ifndef __CS_PARAMEDMEM_REMAPPER_HXX__
2 #define __CS_PARAMEDMEM_REMAPPER_HXX__
5  * Parallel interpolation using ParaMEDMEM OverlapDEC
29  * Local headers
32 #include "cs_defs.h"
34 /*----------------------------------------------------------------------------*/
38 #if defined(HAVE_MEDCOUPLING_LOADER)
40 typedef struct _cs_paramedmem_remapper_t cs_paramedmem_remapper_t;
53 /*----------------------------------------------------------------------------*/
54
55 cs_paramedmem_remapper_t *
57  const char *sel_criteria,
58  char *fileName,
59  char *meshName,
60  cs_real_t center[3],
61  cs_real_t radius);
62
63 /*----------------------------------------------------------------------------*/
83 /*----------------------------------------------------------------------------*/
84
85 cs_real_t *
86 cs_paramedmem_remap_field(cs_paramedmem_remapper_t *r,
87  char *fieldName,
88  cs_real_t dval,
89  int time_choice,
90  double tval);
91
92 /*----------------------------------------------------------------------------*/
100 /*----------------------------------------------------------------------------*/
101
102 cs_paramedmem_remapper_t *
103 cs_paramedmem_remapper_by_name_try(const char *name);
104
105 /*----------------------------------------------------------------------------*/
113
114 void
115 cs_paramedmem_remapper_translate(cs_paramedmem_remapper_t *r,
116  cs_real_t translation[3]);
117
118 /*----------------------------------------------------------------------------*/
128
129 void
130 cs_paramedmem_remapper_rotate(cs_paramedmem_remapper_t *r,
131  cs_real_t invariant[3],
132  cs_real_t axis[3],
133  cs_real_t angle);
134
135 /*----------------------------------------------------------------------------*/
139 /*----------------------------------------------------------------------------*/
140
141 void
143
144 /*----------------------------------------------------------------------------*/
145
146 #endif // HAVE_MEDCOUPLING_LOADER
147
149
150 #endif /* __CS_PARAMEDMEM_REMAPPER_HXX__ */
cs_paramedmem_remapper_t * cs_paramedmem_remapper_by_name_try(const char *name)
get a remapper by its name
Definition: cs_paramedmem_remapper.cxx:529
Definition: cs_defs.h:467
Definition: cs_defs.h:302
cs_paramedmem_remapper_t * cs_paramedmem_remapper_create(char *name, const char *sel_criteria, char *fileName, char *meshName, cs_real_t center[3], cs_real_t radius)
Creates a new cs_paramedmem_remapper_t instance.
Definition: cs_paramedmem_remapper.cxx:490
void cs_paramedmem_remapper_destroy_all(void)
Destroy all remappers.
Definition: cs_paramedmem_remapper.cxx:783
void cs_paramedmem_remapper_translate(cs_paramedmem_remapper_t *r, cs_real_t translation[3])
translate the mesh using a given vector
Definition: cs_paramedmem_remapper.cxx:732
Definition: cs_defs.h:468
cs_real_t * cs_paramedmem_remap_field(cs_paramedmem_remapper_t *r, char *fieldName, cs_real_t dval, int time_choice, double tval)
Interpolate a given field on the local mesh for a given time.
Definition: cs_paramedmem_remapper.cxx:656
void cs_paramedmem_remapper_rotate(cs_paramedmem_remapper_t *r, cs_real_t invariant[3], cs_real_t axis[3], cs_real_t angle)
Rotate the mesh using a center point, axis and angle.
Definition: cs_paramedmem_remapper.cxx:759
