cs_opts.h
1 #ifndef __CS_OPTS_H__
2 #define __CS_OPTS_H__
5  * Parsing of program arguments and associated initializations
31  * Local headers
34 #include "cs_base.h"
41  * Macro definitions
45  * Type definitions
48 /*----------------------------------------------------------------------------
49  * Code_Saturne base options structure
50  *----------------------------------------------------------------------------*/
51
52 typedef struct {
53
54  char *app_name; /* Application name */
55
56  /* Redirection of standard output */
57
58  bool trace; /* Trace progress to stdout */
59  bool logrp; /* Redirection for ranks > 0
60  (false: to "/dev/null", suppressed)
61  true: to "run_solver_n*.log" file) */
62
63  /* Signal handling */
64
65  bool sig_defaults; /* use default signal handlers */
66
67  /* Other options */
68
69  bool preprocess; /* Mesh preprocessing mode */
70  bool verif; /* Mesh quality verification mode */
71  int benchmark; /* Benchmark mode:
72  0: not used;
73  1: timing (CPU + Walltime) mode
74  2: MPI trace-friendly mode */
75
76  /* Connection with YACS */
77
78  char *yacs_module; /* Path to YACS module */
79
80 } cs_opts_t;
81
82 /*=============================================================================
83  * Public function prototypes
84  *============================================================================*/
85
87  * Define options and call some associated initializations
88  * based on command line arguments
89  *
90  * parameters:
91  * argc --> number of command line arguments
92  * argv --> array of command line arguments
93  * opts <-- options structure
94  *----------------------------------------------------------------------------*/
95
96 void
97 cs_opts_define(int argc,
98  char *argv[],
99  cs_opts_t *opts);
100
101 /*----------------------------------------------------------------------------*/
102
104
105 #endif /* __CS_OPTS_H__ */
void cs_opts_define(int argc, char *argv[], cs_opts_t *opts)
Definition: cs_opts.c:188
bool preprocess
Definition: cs_opts.h:69
int benchmark
Definition: cs_opts.h:71
Definition: cs_defs.h:467
bool trace
Definition: cs_opts.h:58
bool sig_defaults
Definition: cs_opts.h:65
char * yacs_module
Definition: cs_opts.h:78
bool verif
Definition: cs_opts.h:70
bool logrp
Definition: cs_opts.h:59
Definition: cs_opts.h:52
Definition: cs_defs.h:468
char * app_name
Definition: cs_opts.h:54
