cs_numbering.h
1 #ifndef __CS_NUMBERING_H__
2 #define __CS_NUMBERING_H__
5  * Numbering information for vectorization or multithreading
31  * Local headers
34 #include "cs_defs.h"
35 #include "cs_base.h"
36 #include "cs_log.h"
43  * Macro definitions
45
46 /* SIMD unit length */
47 /*------------------*/
48
49 #if defined(__NEC__) && defined(__ve__) /* For NEC Aurora series */
50
51 # define CS_NUMBERING_SIMD_SIZE 256
52
53 #elif defined(SX) && defined(_SX) /* For NEC SX series (at least SX-9) */
54
55 # define CS_NUMBERING_SIMD_SIZE 256
56
57 #elif defined(__AVX512F__) /* For Intel with AVX 512 */
58
59 # define CS_NUMBERING_SIMD_SIZE 64
60
61 #else
62
63 # define CS_NUMBERING_SIMD_SIZE 4 /* Most current platforms */
64
65 #endif
66
67 /*============================================================================
68  * Type definitions
69  *============================================================================*/
70
71 /* Renumbering types */
72
73 typedef enum {
74
75  CS_NUMBERING_DEFAULT, /* Default numbering */
76  CS_NUMBERING_VECTORIZE, /* Numbered for vectorization */
77  CS_NUMBERING_THREADS /* Numbered for threads */
78
80
81 /* Renumbering structure */
82
83 typedef struct {
84
85  cs_numbering_type_t type; /* Numbering type */
86
87  int vector_size; /* Vector size if vectorized, 1 otherwise */
88
89  int n_threads; /* Number of threads */
90  int n_groups; /* Number of associated groups */
91
92  int n_no_adj_halo_groups; /* number of groups for which only non-ghost
93  entities are adjacent */
94
95  cs_lnum_t n_no_adj_halo_elts; /* Number of elements not adjacent to
96  halo elements */
97
98  cs_lnum_t *group_index; /* For thread t and group g, the start and
99  past-the-end ids for entities in a given
100  group and thread are respectively:
101  group_index[t*n_groups*2 + g] and
102  group_index[t*n_groups*2 + g + 1].
103  (size: n_groups * n_threads * 2) */
104
106
107 /*=============================================================================
108  * Global variable definitions
109  *============================================================================*/
110
111 /* Names for numbering types */
112
113 extern const char *cs_numbering_type_name[];
114
115 /*============================================================================
116  * Public function prototypes for Fortran API
117  *============================================================================*/
118
119 /*=============================================================================
120  * Public function prototypes
121  *============================================================================*/
122
123 /*----------------------------------------------------------------------------*/
131 /*----------------------------------------------------------------------------*/
132
135
136 /*----------------------------------------------------------------------------*/
147
150  int vector_size);
151
152 /*----------------------------------------------------------------------------*/
166 /*----------------------------------------------------------------------------*/
167
169 cs_numbering_create_threaded(int n_threads,
170  int n_groups,
171  cs_lnum_t group_index[]);
172
173 /*----------------------------------------------------------------------------*/
180 /*----------------------------------------------------------------------------*/
181
182 void
184
185 /*----------------------------------------------------------------------------*/
193 /*----------------------------------------------------------------------------*/
194
195 void
197  const char *description,
198  const cs_numbering_t *numbering);
199
200 /*----------------------------------------------------------------------------*/
206 /*----------------------------------------------------------------------------*/
207
208 void
209 cs_numbering_dump(const cs_numbering_t *numbering);
210
211 /*----------------------------------------------------------------------------*/
212
214
215 #endif /* __CS_NUMBERING_H__ */
Definition: cs_numbering.h:85
const char * cs_numbering_type_name[]
Definition: cs_numbering.c:73
Definition: cs_numbering.h:92
void cs_numbering_destroy(cs_numbering_t **numbering)
Destroy a numbering information structure.
Definition: cs_numbering.c:634
Definition: cs_defs.h:467
Definition: cs_numbering.h:77
cs_numbering_t * cs_numbering_create_threaded(int n_threads, int n_groups, cs_lnum_t group_index[])
Create a default numbering information structure in case of threading.
Definition: cs_numbering.c:597
cs_numbering_t * cs_numbering_create_vectorized(cs_lnum_t n_elts, int vector_size)
Create a default numbering information structure in case of vectorization.
Definition: cs_numbering.c:556
void cs_numbering_log_info(cs_log_t log, const char *description, const cs_numbering_t *numbering)
Log information relative to a cs_numbering_t structure.
Definition: cs_numbering.c:657
Definition: cs_numbering.h:76
cs_lnum_t * group_index
Definition: cs_numbering.h:98
int vector_size
Definition: cs_numbering.h:87
Definition: cs_numbering.h:75
cs_log_t
Definition: cs_log.h:48
int n_groups
Definition: cs_numbering.h:90
Definition: cs_defs.h:298
void cs_numbering_dump(const cs_numbering_t *numbering)
Dump a cs_numbering_t structure.
Definition: cs_numbering.c:745
Definition: cs_defs.h:468
int n_threads
Definition: cs_numbering.h:89
cs_numbering_type_t
Definition: cs_numbering.h:73
Definition: cs_numbering.h:95
cs_numbering_t * cs_numbering_create_default(cs_lnum_t n_elts)
Create a default numbering information structure.
Definition: cs_numbering.c:520
Definition: cs_numbering.h:83
