cs_map.h
1 #ifndef __CS_MAP_H__
2 #define __CS_MAP_H__
5  * Map helper structures
31  * Local headers
34 #include "cs_base.h"
41  * Macro definitions
45  * Type definitions
48 typedef struct _cs_map_name_to_id_t cs_map_name_to_id_t;
49
51  * Global variables
53
54 /*=============================================================================
55  * Public function prototypes for Fortran API
57
58 /*=============================================================================
61
62 /*----------------------------------------------------------------------------
63  * Create empty name to id map.
64  *
65  * returns:
66  * pointer to newly initialized map structure.
67  *----------------------------------------------------------------------------*/
68
71
72 /*----------------------------------------------------------------------------
73  * Destroy name to id map structure.
74  *
75  * parameters:
76  * m <-> pointer to map structure.
77  *----------------------------------------------------------------------------*/
78
79 void
81
82 /*----------------------------------------------------------------------------
83  * Find id matching a key, inserting key if not already present.
84  *
85  * parameters:
86  * m <-> pointer to map structure
87  * key <-- character string (key)
88  *
89  * returns:
90  * id matching key (already present or newly inserted)
91  *----------------------------------------------------------------------------*/
92
93 int
95  const char *key);
96
97 /*----------------------------------------------------------------------------
98  * Return id matching a key, or -1 if not present.
99  *
100  * parameters:
101  * m <-- pointer to map structure
102  * key <-- character string (key)
103  *
104  * returns:
105  * id matching key, or -1.
106  *----------------------------------------------------------------------------*/
107
108 int
110  const char *key);
111
112 /*----------------------------------------------------------------------------
113  * Return a key name in a map matching a given id.
114  *
115  * parameters:
116  * m <-- pointer to map structure.
117  * id <-- key id
118  *
119  * returns:
120  * pointer to key.
121  *----------------------------------------------------------------------------*/
122
123 const char *
125  size_t id);
126
127 /*----------------------------------------------------------------------------
128  * Return the size of a map.
129  *
130  * parameters:
131  * m <-- pointer to map structure.
132  *
133  * returns:
134  * number of entries in map.
135  *----------------------------------------------------------------------------*/
136
137 size_t
139
140 /*----------------------------------------------------------------------------
141  * Return key in a map for a given index position.
142  *
143  * parameters:
144  * m <-- pointer to map structure.
145  * index <-- key index
146  *
147  * returns:
148  * pointer to key.
149  *----------------------------------------------------------------------------*/
150
151 const char *
153  size_t index);
154
155 /*----------------------------------------------------------------------------*/
156
158
159 #endif /* __CS_MAP_H__ */
cs_map_name_to_id_t * cs_map_name_to_id_create(void)
Definition: cs_map.c:195
Definition: cs_defs.h:467
const char * cs_map_name_to_id_reverse(const cs_map_name_to_id_t *m, size_t id)
Definition: cs_map.c:348
void cs_map_name_to_id_destroy(cs_map_name_to_id_t **m)
Definition: cs_map.c:224
Definition: cs_map.h:48
const char * cs_map_name_to_id_key(const cs_map_name_to_id_t *m, size_t index)
Definition: cs_map.c:394
Definition: cs_defs.h:468
size_t cs_map_name_to_id_size(const cs_map_name_to_id_t *m)
Definition: cs_map.c:372
int cs_map_name_to_id_try(const cs_map_name_to_id_t *m, const char *key)
Definition: cs_map.c:300
int cs_map_name_to_id(cs_map_name_to_id_t *m, const char *key)
Definition: cs_map.c:256
