cs_les_inflow.h
1
2 #ifndef __CS_LES_INFLOW_H__
3 #define __CS_LES_INFLOW_H__
4
5 /*============================================================================
6  * Turbulent inflow generation
8
9 /*
10  This file is part of Code_Saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2019 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
30
31 #include "cs_defs.h"
32
33 /*----------------------------------------------------------------------------
34  * Local headers
35  *----------------------------------------------------------------------------*/
36
37 #include "cs_base.h"
38
44  * Macro definitions
46
48  * Type definitions
50
51 /*----------------------------------------------------------------------------
52  * Type of synthetic turbulence generation
53  *----------------------------------------------------------------------------*/
54
55 typedef enum {
56
57  CS_INFLOW_LAMINAR, /* Laminar fluctuations (i.e no fluctuation) */
58  CS_INFLOW_RANDOM, /* Gaussian random fluctuation */
59  CS_INFLOW_BATTEN, /* Fluctuations generated by the Batten method */
60  CS_INFLOW_SEM /* Fluctuations generated by the Synthetic Eddy Method */
61
63
64 /*=============================================================================
65  * Local Structure Definitions
66  *============================================================================*/
67
68 /* Inlet definition */
69 /*------------------*/
70
71 typedef struct _cs_inlet_t cs_inlet_t;
72
73 /*=============================================================================
74  * Public function prototypes for Fortran API
75  *============================================================================*/
76
77 /*----------------------------------------------------------------------------
78  * Creation of a structure for the inlets
79  *----------------------------------------------------------------------------*/
80
81 void CS_PROCF(defsyn, DEFSYN)
82 (
83  cs_int_t *n_inlets /* <-- number of inlets */
84 );
85
87  * General synthetic turbulence generation
88  *----------------------------------------------------------------------------*/
89
90 void CS_PROCF(synthe, SYNTHE)(
91  const cs_int_t *const nvar, /* --> number of variables */
92  const cs_int_t *const nscal, /* --> number of scalars */
93  const cs_int_t *const iu, /* --> index of velocity component */
94  const cs_int_t *const iv, /* --> index of velocity component */
95  const cs_int_t *const iw, /* --> index of velocity component */
96  const cs_real_t *const ttcabs, /* --> current physical time */
97  const cs_real_t dt[], /* --> time step */
98  cs_real_t rcodcl[] /* <-> boundary conditions array */
99 );
100
101 void CS_PROCF(cs_user_les_inflow_init, CS_USER_LES_INFLOW_INIT)(
102  cs_int_t *nent /* <-- number of LES inlets */
103 );
104
105 void CS_PROCF(cs_user_les_inflow_define, CS_USER_LES_INFLOW_DEFINE)(
106  const cs_int_t *const nument, /* --> id of the inlet */
107  int *typent, /* <-- type of inflow method at the inlet */
108  int *nelent, /* <-- numb. of entities of the inflow meth*/
109  int *iverbo, /* <-- verbosity level */
110  cs_int_t *nfbent, /* <-- numb. of bound. faces of the inlet */
111  cs_int_t lfbent[], /* <-- list of bound. faces of the inlet */
112  cs_real_t vitent[], /* <-- ref. mean velocity at the inlet */
113  cs_real_t *enrent, /* <-- ref. turb. kin. ener. at the inlet */
114  cs_real_t *dspent /* <-- ref. turb. dissipation at the inlet */
115 );
116
117 void CS_PROCF(cs_user_les_inflow_advanced, CS_USER_LES_INFLOW_ADVANCED)(
118  const cs_int_t *const nument, /* --> id of the inlet */
119  const cs_int_t *const nfbent, /* --> numb. of bound. faces of the inlet */
120  const cs_int_t *const nvar, /* --> number of variables */
121  const cs_int_t *const nscal, /* --> number of scalars */
122  const cs_int_t lfbent[], /* --> list of bound. faces of the inlet */
123  const cs_real_t dt[], /* --> time step */
124  cs_real_t uent[], /* <-- mean velocity at the inlet faces */
125  cs_real_t rijent[], /* <-- turb. kin. ener. at the inlet faces */
126  cs_real_t epsent[] /* <-- turb. dissipation at the inlet faces*/
127 );
128
129 /*----------------------------------------------------------------------------
130  * Read the restart file of the LES inflow module
131  *----------------------------------------------------------------------------*/
132
133 void CS_PROCF(lecsyn, LECSYN)
134 (
135  const char *filename
136 );
137
138 /*----------------------------------------------------------------------------
139  * Write the restart file of the LES inflow module
140  *----------------------------------------------------------------------------*/
141
142 void CS_PROCF(ecrsyn, ECRSYN)
143 (
144  const char *filename
145 );
146
147 /*=============================================================================
148  * Public function prototypes
149  *============================================================================*/
150
151 /*----------------------------------------------------------------------------
152  * Finalize turbulent inflow generation API.
153  *----------------------------------------------------------------------------*/
154
155 void
156 cs_inflow_finalize(void);
157
158 /*----------------------------------------------------------------------------*/
159
161
162 #endif /* __CS_LES_INFLOW_H__ */
void synthe(const cs_int_t *const nvar, const cs_int_t *const nscal, const cs_int_t *const iu, const cs_int_t *const iv, const cs_int_t *const iw, const cs_real_t *const ttcabs, const cs_real_t dt[], cs_real_t rcodcl[])
Definition: cs_les_inflow.c:1319
Definition: cs_les_inflow.h:59
cs_inflow_type_t
Definition: cs_les_inflow.h:55
integer, save iv
Definition: numvar.f90:63
void lecsyn(const char *filename)
Definition: cs_les_inflow.c:1517
integer, save iu
Definition: numvar.f90:59
void cs_inflow_finalize(void)
Definition: cs_les_inflow.c:2213
void ecrsyn(const char *filename)
Definition: cs_les_inflow.c:1934
void cs_user_les_inflow_init(cs_int_t *nent)
Definition: cs_defs.h:467
int cs_int_t
Fortran-compatible integer.
Definition: cs_defs.h:301
void defsyn(cs_int_t *n_inlets)
Definition: cs_les_inflow.c:1214
void cs_user_les_inflow_define(const cs_int_t *const nument, int *typent, int *nelent, int *iverbo, cs_int_t *nfbent, cs_int_t lfbent[], cs_real_t vitent[], cs_real_t *enrent, cs_real_t *dspent)
void cs_user_les_inflow_advanced(const cs_int_t *const nument, const cs_int_t *const nfbent, const cs_int_t *const nvar, const cs_int_t *const nscal, const cs_int_t lfbent[], const cs_real_t dt[], cs_real_t uent[], cs_real_t rijent[], cs_real_t epsent[])
Definition: cs_les_inflow.h:57
Definition: cs_defs.h:302
real(c_double), pointer, save ttcabs
Current absolute time.
Definition: optcal.f90:400
integer, save iw
Definition: numvar.f90:67
integer, save nvar
number of solved variables (must be lower than nvarmx)
Definition: dimens.f90:42
Definition: cs_les_inflow.h:71
Definition: cs_defs.h:468
integer, save nscal
number of solved user scalars effective number of scalars solutions of an advection equation...
Definition: dimens.f90:55
#define CS_PROCF(x, y)
Definition: cs_defs.h:481
Definition: cs_les_inflow.h:60
Definition: cs_les_inflow.h:58
