cs_join.h
1 #ifndef __CS_JOIN_H__
2 #define __CS_JOIN_H__
5  * Structure and function headers handling with joining operation
6  *===========================================================================*/
31  * Local headers
32  *---------------------------------------------------------------------------*/
34 #include "cs_base.h"
35 #include "cs_join_util.h"
36 #include "cs_mesh.h"
38 /*---------------------------------------------------------------------------*/
42 /*=============================================================================
43  * Local Macro definitions
44  *===========================================================================*/
45
47  * Type definition
48  *===========================================================================*/
49
50 /*=============================================================================
51  * Global variables
52  *===========================================================================*/
53
54 /*=============================================================================
55  * Public function prototypes
56  *===========================================================================*/
57
58 /*----------------------------------------------------------------------------
59  * Add a cs_join_t structure to the list of pending joinings.
60  *
61  * parameters:
62  * sel_criteria <-- boundary face selection criteria
63  * fraction <-- value of the fraction parameter
64  * plane <-- value of the plane parameter
65  * verbosity <-- level of verbosity required
66  * visualization <-- level of visualization required
67  *
68  * returns:
69  * number (1 to n) associated with new joining
70  *---------------------------------------------------------------------------*/
71
72 int
73 cs_join_add(const char *sel_criteria,
74  float fraction,
75  float plane,
76  int verbosity,
77  int visualization);
78
79 /*----------------------------------------------------------------------------
80  * Set advanced parameters for the joining algorithm.
81  *
82  * parameters:
83  * join_num <-> joining operation number
84  * mtf <-- merge tolerance coefficient
85  * pmf <-- pre-merge factor
86  * tcm <-- tolerance computation mode
87  * icm <-- intersection computation mode
88  * max_break <-- max number of equivalences to break (merge step)
89  * max_sub_faces <-- max. possible number of sub-faces by splitting a face
90  * tml <-- tree max level
91  * tmb <-- tree max boxes
92  * tmr <-- tree max ratio
93  * tmr_distrib <-- tree max ratio for distribution
94  *---------------------------------------------------------------------------*/
95
96 void
97 cs_join_set_advanced_param(int join_num,
98  double mtf,
99  double pmf,
100  int tcm,
101  int icm,
102  int max_break,
103  int max_sub_faces,
104  int tml,
105  int tmb,
106  double tmr,
107  double tmr_distrib);
108
109 /*----------------------------------------------------------------------------
110  * Apply all the defined joining operations.
111  *
112  * parameters:
113  * preprocess <-- true if we are in the preprocessing stage
114  *---------------------------------------------------------------------------*/
115
116 void
117 cs_join_all(bool preprocess);
118
119 /*----------------------------------------------------------------------------
120  * Clear remaining memory for defined joining operations.
121  *---------------------------------------------------------------------------*/
122
123 void
124 cs_join_finalize(void);
125
126 /*----------------------------------------------------------------------------
127  * Flag boundary faces that will be selected for joining.
128  *
129  * parameters:
130  * mesh <-- pointer to mesh structure
131  * preprocess <-- true if we are in the preprocessing stage
132  * b_select_flag <-> false for boundary faces not selected for joining,
133  * true for those selected
134  *---------------------------------------------------------------------------*/
135
136 void
138  bool preprocess,
139  bool b_select_flag[]);
140
141 /*---------------------------------------------------------------------------*/
142
144
145 #endif /* __CS_JOIN_H__ */
void cs_join_set_advanced_param(int join_num, double mtf, double pmf, int tcm, int icm, int max_break, int max_sub_faces, int tml, int tmb, double tmr, double tmr_distrib)
Definition: cs_join.c:1636
Definition: cs_defs.h:467
void cs_join_all(bool preprocess)
Definition: cs_join.c:1690
Definition: cs_mesh.h:63
void cs_join_mark_selected_faces(const cs_mesh_t *mesh, bool preprocess, bool b_select_flag[])
Definition: cs_join.c:2024
void cs_join_finalize(void)
Definition: cs_join.c:1992
integer, save icm
the intersection computation mode. If its value is:
Definition: ppincl.f90:293
Definition: cs_defs.h:468
Definition: mesh.f90:26
int cs_join_add(const char *sel_criteria, float fraction, float plane, int verbosity, int visualization)
Definition: cs_join.c:1591
