bft_mem_usage.h
1 #ifndef __BFT_MEM_USAGE_H__
2 #define __BFT_MEM_USAGE_H__
5  * Base memory usage information (System and Library dependent)
30 #include "cs_defs.h"
36 /*============================================================================
37  * Public types
41  * Public function prototypes
44 /*
45  * Initialize memory usage count depending on system.
46  *
47  * This functions checks if it has already been called, so
48  * it is safe to call more than once (though it is not
49  * thread-safe). Only the first call is effective.
50  */
51
52 void
53 bft_mem_usage_init(void);
54
55 /*
56  * End memory usage count depending on system.
57  */
58
59 void
60 bft_mem_usage_end(void);
61
62 /*
63  * Indicates if bft_mem_usage_...() functions are initialized.
64  *
65  * returns:
66  * 1 if bft_mem_usage_init has been called, 0 otherwise.
67  */
68
69 int
71
72 /*
73  * Return current process memory use (in kB) depending on OS.
74  */
75
76 size_t
78
79 /*
80  * Return maximum process memory use (in kB) depending on OS.
81  *
82  * The returned value is the maximum returned by bft_mem_usage_pr_size()
83  * during the program's lifetime. With memory allocations which return
84  * memory to the system, this value could be incorrect in certain cases.
85  */
86
87 size_t
89
90 /*
91  * Return counter to number of calls to malloc, realloc, and free.
92  *
93  * This function returns zeroes when the appropriate instrumentation
94  * is not available.
95  */
96
97 void
98 bft_mem_usage_n_calls(size_t count[3]);
99
100 /*----------------------------------------------------------------------------*/
101
103
104 #endif /* __BFT_MEM_USAGE_H__ */
size_t bft_mem_usage_pr_size(void)
Return current process memory use (in kB) depending on system.
Definition: bft_mem_usage.c:723
void bft_mem_usage_init(void)
Definition: bft_mem_usage.c:452
Definition: cs_defs.h:467
size_t bft_mem_usage_max_pr_size(void)
Definition: bft_mem_usage.c:739
int bft_mem_usage_initialized(void)
Definition: bft_mem_usage.c:497
Definition: cs_defs.h:468
void bft_mem_usage_n_calls(size_t count[3])
Definition: bft_mem_usage.c:754
void bft_mem_usage_end(void)
Definition: bft_mem_usage.c:483
