| integer(c_int), pointer, save | iale |
| | Activates (=1 o) or not (=0), activate the ALE module: More...
| integer, save | nalinf |
| | the number of sub-iterations of initialization of the fluid More...
| integer, save | nalimx |
| | maximum number of imlicitation iterations of of the structure displacement More...
| double precision, save | epalim |
| | relative precision of implicitation of the structure displacement More...
| integer, save | italin |
| | iteration (yes=1, no=0) to initialize ALE More...
| integer, dimension(:), allocatable | impale |
| | indicator of imposed displacement More...
| integer, dimension(:), allocatable | ialtyb |
| | defines the mesh velocity from the color of the boundary faces, or more generally from their properties (colors, groups, ...), from the boundary conditions defined in cs user boundary conditions, or even from their coordinates. More...
| double precision, dimension(:,:), allocatable | xyzno0 |
| | initial mesh coordinates More...
| integer, save | fdiale |
| | Pointer to field over vertices: mesh displacement. More...
Module for Arbitrary Lagrangian Eulerian method (ALE)
